So it's been a year since I removed my tranny...
Old Jul 31, 2007 | 12:23 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default So it's been a year since I removed my tranny...
What's the long cable with the 4wd tag for? Don't say 4wd!! I never had shiftable 4wd -- it was full time AWD.
Also, what's the threaded end on the shaft that sticks through the neutral safety switch for? Is there a nut that's supposed to go there? And why? lol
Old Jul 31, 2007 | 12:35 AM
Quik's Avatar
5 year bitches!
that shaft is the selector for the gears on the trans. yes a 15mm head nut went there that held the cable
that cable i bet has a sqaure opening on it that goes to the shaft you spoke of. it says 4wd cause of the lenght that was needed. my truck used to say 2wd.. AWD/4wd had similar parts thus same cable
Old Jul 31, 2007 | 03:30 AM
KySilverado's Avatar
Yeah sounds like your gear selector cable. Threaded shaft then the neutral safety switch slides over it. Held with with two bolts, then the gear shift lever with a 15mm nut.
Sorry, Kind of blurry. Looking up and rearward of tranny.
Old Jul 31, 2007 | 09:06 AM
I AM A MOTHERF*CKER
AH... I'm missing the shift lever. DOH!
Thanks fellas.
Choda
Jan 22, 2026 02:03 PM
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
