slotted vs. slotted/drilled rotors
Originally Posted by TBSS
Twenty years ago when pad materials were inferior, there was such a thing as 'gas buildup.' Now, even OEM pad materials are such that countering this is not required. Also, GM OEM rotors are Brembo blanks, which are pretty damn good rotors, and what some manufacturers use to drill on or grind slots into.
The fact is, if you are not going to upgrade rotor diameter, you should leave your stock rotors alone. The best thing you can do for braking PERFORMANCE short of upgrading with an entire kit is the following:
1) Upgrade pads (i.e. Hawk HPS or similar)
2) Upgrade your fluid to DOT 4 (i.e. ATE Super Blue)
3) Install stainless steel brake lines
I definitely agree on your list above, from what I have read on here people have great success with just those 3.
I got a pair of these off ebay for 128 shipped .
They are zinc coated and so far haven't rusted at all.
Braking feels like stock, not sure if they help with brake fade while towing, havn't towed since I put them on. Here's a picture,
(I didn't even know the inside of my OEM rotors even looked like that, the outsides looked normal.) Kind of scary...
14 Second Truck Club
Originally Posted by LS1TRUCKGUY
you should look into the ssbc brake kit. they are nice. 400 bucks gets you 4 slotted rotors and pads
Thanks for all the info guys!
Moderately Differentiated
yeh, no resurfacing!
I down graded from my brembo's back to stock due the cost of replacing my shot brembo rotors. But if you do upgrade and want performance, get the bigger rotor and the new hardware. My brembo 4 pistons are f-ing night and day from the stock setup in stopping power.
