Slip Yoke for 4L80E? 2001 2WD ECSB
Been researching the 80E swap and am getting confused about the slip yoke. I understand I need a new one, but which one? Is there a direct-fit? I've read of people having to cut down the slip yoke anywhere from 0.5-2". Is there one that requires no cutting?
Is there a particular brand that I don't have to worry about breaking? I've read about some of the eBay yokes breaking.
And lastly, how do I swap the slip yoke onto the stock driveshaft? Any special tools required?
This is an 2001 2WD extended cab with the stock 2-piece driveshaft.
Ebay is where I got mine. Cut it down 5/8ths of an inch. I took it to a machine shop $25
Link to Yoke:
http://www.ebay.com/itm/GM-Turbo-400...1bbd57&vxp=mtr
Here is a pic of mine:
https://www.performancetrucks.net/fo...5/#post5033527
Link to Yoke:
Is a press required to install the slip yoke onto the driveshaft? I've been looking for a how-to but haven't been able to find one.
And would there be any advantage to getting something like a 1330 slip yoke and then a 1330/3R combination u-joint?
If you have never installed a Ujoint, then take it somewhere. Much less headache.
Ive done a few ujoints in the past but this last time i couldnt get the cups to budge in the yokes with a Arbor press. Took it to the powertrain place and $50 i had 3 new ujoints and they installed them.
The 4wd trucks use the yoke that will fit the 80E. My buddys 1998 truck was a 4wd. Took the yoke off and put it on a 2wd DS and it fit perfect.
