Simple question on what tool to use.
Old Apr 18, 2010 | 12:01 PM
SK03Z71's Avatar
Default Simple question on what tool to use.
I need to get an impact fitting to remove the caliper bolts. It appears to be @ a 55 torx. These are '03 stock front calipers. Can someone tell me the correct size? Also any tips to ease the job would be appreciated.
Old Apr 18, 2010 | 12:03 PM
00ChevyScott's Avatar
Wearin' da big hat
I think it is a T55.
Old Apr 18, 2010 | 02:07 PM
budhayes3's Avatar
PT's Slowest Truck
Make sure that the torx socket it completely seated in the bolt head before you break it loose, or you will either twist the tool or strip the bolt head...happens real easily with torx...and break it loose by hand, then run it off with the gun if using air. My buddy stripped out my T55 Torx that way when we did his brakes, luckily I had a backup.
blownss27
Aug 14, 2020 08:27 AM
custm2500
Sep 8, 2015 05:53 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
LT-1 SS
Sep 3, 2015 07:31 AM
