Silverado Handling
Old Sep 14, 2006 | 12:38 AM
benvortec's Avatar
Default Silverado Handling
What are the best mods you can make to a 2 wheel drive silverado to make it handle more "car-like"? I was just wondering, thanks!
Old Sep 14, 2006 | 07:06 AM
SSlow 4.8's Avatar
add a performance rear sway bar, and replace the front sway bar with a lighter/one made for handling.
mcgaughys has a lowering/handling kit i beleive as well.
Old Sep 14, 2006 | 08:48 AM
Beastofa327's Avatar
Hotchkis Anti-swaybar kit. http://www.tbyrne.com/truckcatalog.html one of our sponsers--->
Old Sep 14, 2006 | 11:13 AM
negativeswitches's Avatar
my swaybars work miracles in the corners
Old Sep 14, 2006 | 12:18 PM
hotchkis TVS. i have heard very good things and it gets you a 2/4 to boot
Old Sep 14, 2006 | 03:10 PM
GoldenVelvet's Avatar
The TVS is really hard to beat.
Basically you want your truck to remain as flat as possible and as consistent as possible in turns. No suspension type is truly better then any other. Some are just more tunable (see first sentence)
There are many things you can do to make it handle better. The easiest is sway bars; well tuned sway bars can be worth as much as .25g's. Lowering your truck also lowers the center of gravity (both instant and imaginary center of gravity). Stiffer springs also offers more consistent handling. Then there are the little things that add to handling such as stiffer rubber in suspentions (as suspension deflection is bad) such as poly graphite, polyurethane, ect. Some sort of device to keep your rear axle centered, such as a watts link or panhard bar, also improves consistency and handling. And obviously matched shocks help. The most important part of you suspension is your tires. Good tires make all the difference.
If you want small improvements with a good bang for the buck, sway bars. If you want a bit more the TVS is a good bet as Hotchkis is the ONLY manufacturer that makes increased spring rates for our trucks (unless you want to get something custom made) It just depends on how far you want to go. Figure a stock 2wd truck pulls something like a .5 or .6. How much more do you want?
Old Sep 14, 2006 | 05:16 PM
listen to golden, from what i have experienced and read, he's the man when it comes to suspension dynamics
Old Sep 14, 2006 | 08:16 PM
TimDave217
Aug 5, 2015 04:04 PM
DwDrummer
Jul 24, 2015 07:05 AM
Ketis
Jul 23, 2015 12:37 PM
low2001gmc
Jul 21, 2015 02:09 PM
