Should I go 14 bolt
Old Apr 25, 2016 | 05:00 AM
  #31
Suburbazine's Avatar
There's maybe 40 lbs of difference between a 10 bolt and a 14 bolt...
I just swapped so I would know lol.
http://imageshack.com/a/img905/5522/yuc9x2.jpg
http://imageshack.com/a/img923/4306/6NpXIB.jpg
There is no such thing as a 10 bolt that will hold up under power. I tore the spider carrier off the ring gear, twisted both axle shafts and cracked the diff housing around the pinion:
Old Apr 25, 2016 | 05:17 PM
  #32
1FastBrick's Avatar
Custm2500's Rude Friend
To me, the most impressive 10 bolt destruction was EvilGMC's.
It literally sheared all the teeth off the ring gear, Twisted the axle shafts, and spun the slicks 3/4 away around the rim. The Limited slip stayed together as well as the girdle cap, but everything else was junk!!!
He went with a custom 14 bolt and proceeded to Blow the built 4L80E trans.
Old Apr 25, 2016 | 05:34 PM
  #33
lxcoupe's Avatar
Who on this forum has officially grenaded a 10 bolt on a 4wd/awd launch?
Old Apr 25, 2016 | 06:24 PM
  #34
George C....'s Avatar
Formerly ScreamingL
When I **** **** up...I do it on expert level
Attached Thumbnails Should I go 14 bolt-1502333_678627832187380_1540690034_o.jpg   Should I go 14 bolt-1486161_680384272011736_2042199710_o.jpg
Old Apr 25, 2016 | 08:18 PM
  #35
RS/SS 4.8's Avatar
10 Second Truck Club
Damn.
Old Apr 25, 2016 | 09:08 PM
  #36
I bent that stainless steel spider shaft into a 20 degree angle in the middle and got it stuck between the ring gear and diff cover haha. Mine died leaving from a stop though so it didn't get to build the steam to chuck parts out.
Old Apr 26, 2016 | 07:25 PM
  #37
Nicely done!
Old Apr 26, 2016 | 07:26 PM
  #38
Do you happen to have a link? I would like to see this carnage. If not I can just search his name.
Old Apr 26, 2016 | 07:28 PM
  #39
Originally Posted by BlackGMC
Does anyone know if the a new driveshaft is required length wise? I think the ujoints are different but just curious if they are roughly in the same spot.
A new driveshaft is not required, just swap out the u joint. It takes a bastard u joint depending on what u joint your driveshaft has because the 14 bolt takes a 1350 u joint. You will also need new u joint straps to fit the 1350 because the straps off the 10 bolt won't work ( Bigger caps on the u joint )
Last edited by charlie_gonzales; Apr 26, 2016 at 07:57 PM. Reason: Cleaned up my cluster of a post
Old Apr 26, 2016 | 07:40 PM
  #40
tgui's Avatar
You're an artist of destruction.
