Should be an easy U-joint question??
Old Feb 25, 2015 | 05:45 PM
leonpiper69's Avatar
Default Should be an easy U-joint question??
99 GMC Sierra extended cab 4x4. One piece Alum shaft.
U joint started squeaking and then a little vibration and I checked and sure enough it is the front U-joint.
Changin U-joints, not a problem.
Figuring out the correct one.......................................
I used to work for advance yrs ago so I know how to look up parts but because this truck is a 99 everything seems to be weird for it.
I went to advance and they/we could not figure out which joint fits it.
There are tons of listing for two piece shafts (advance told me there was no one piece for that yr LOL) but not one piece. And they list steel but not aluminum.
I was hoping this is easy. I tried searching and couldn't find the answer.
Any thoughts?
Old Feb 25, 2015 | 08:09 PM
RS/SS 4.8's Avatar
10 Second Truck Club
On the 99 and 2000 gm trucks i just order everything for a 01 since by then every ones computers show the right stuff, for example i ordered a window regulator for a 99+ sierra and they got me one for a previous body style 99 sierra.
Old Feb 25, 2015 | 09:27 PM
I am probably going to just have to pull it and take it in to match it up. But I would rather just get the right part number and order it from rock auto.
The thing that has always blown my mind is why there are sooooo many joints for similar applications. I mean it's a truck........unless it's a 1 ton or higher they should just all be the same.
Well except for alum vs steel shafts, that I get.
Old Feb 27, 2015 | 09:06 AM
Well, after trying to match it to a whole bunch of u-joints, it turned out to be a moog 354.
At least that is the one for the front.
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
