shims/wedges to adjust pinion angle
Old Dec 11, 2010 | 10:25 AM
YodiBrodi's Avatar
Default shims/wedges to adjust pinion angle
added hangers this weekend for a total of 3" (2" hangers + 1" shackle) drop in the rear to level truck. i noticed last night i get a light shudder in 1st and 2nd gear on WOT accel. i know my pinion angle is all jacked now, even more positive than stock and way more than when i had just 2" shackles. where is a good source to buy the wedges to readjust the angle? my guess would be i need 1-2 deg wedges, am i correct?
Old Dec 11, 2010 | 10:39 AM
Bigredmariner's Avatar
You can pick some up at most auto parts stores. Last set I got was at O'Reilly's and they had 1 and 2 degree available.
Old Dec 11, 2010 | 01:41 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You need to measure the angles on your truck, then get the correct shims. I ordered mine from Calvert Racing.
Old Dec 11, 2010 | 02:12 PM
TXsilverado's Avatar
measure what you have before you go changing stuff. just park it on a level surface and measure according to the ground.
Old Dec 29, 2010 | 12:06 PM
BadAssChevy327's Avatar
Hangers and shackles haven't positive 6 degrees. I would need a 8 degree shim to get it where I want it now. But check stylintrucks
Old Dec 29, 2010 | 07:49 PM
Truckshop's Avatar
check 4wd shops also. i found some 6 degree shims for mine.
MikeD.
Oct 13, 2015 08:08 AM
Tigger Welder
Oct 1, 2015 08:41 AM
01silvy
Sep 26, 2015 10:20 PM
97_ek
Sep 23, 2015 09:16 PM
