Shimmy: Measured pinion angle - need some help now
#21
Originally Posted by Colby 04
you can point out mistakes in that drawing all day long - it was made in about 10 minutes with ms paint - do you really think I was aiming for it to be drawn to scale and replicate accurate angles? NO
BTW, I'm not mad at all, so carry on whicha bad self
btw - cute images
#22
Originally Posted by BigCountryx
Take your blinders off and read what I wrote, I don't care if it's to scale or not (sorry I ever mentioned that) I'm just saying that one theory doesn't work for every application and for you to act as if it does is steering people in the wrong direction.
btw - cute images
btw - cute images
There's only one way in this case.
Jim
#23
Originally Posted by CHEVY6000VHO
May be true, but this thread was intended for a truck that is dropped 2" in the rear using shackles "only".
Jim
Jim
#25
That's my point, I guarantee if I raised my pinion with shackles only it would be worse. It's not only one way in this case. I had to raise my carrier bearing in order to allign my rear shaft. I'll keep my mouth shut now, believe what you want.
The shackles only will definately lower the snout of the diff. Therefore, it would have to be raised back up to get the proper angle.
If you raise your carrier bearing, it will make it even worse than it was after "only" shackles were installed.
I'm just not understanding your point of view I guess.
Not being rude man, but ****, I don't see how you would have to lower the snout even more after the shackles already did that.
Enlighten me please.
Jim
#26
Originally Posted by blue 01
When you put the stock shackle back on go and drive it around to make sure your vibration is gone.
#27
How is that possible? When you say, "raised my pinion" are you refering to raising the nose of the diff upward?
Jim
Jim
Tigger Welder
Oct 1, 2015 08:41 AM
