Shift Kit vs Tune
Old Nov 10, 2008 | 02:30 PM
dug's Avatar
dug
Banned
Default Shift Kit vs Tune
Can you get all the benefits of a shift kit by tuning? What does the shift kit do? Just raise the line pressure? Does it do anything else?
Im looking for firmer shifts for better durability. Currently the 1-2 shift at wot is taking too long. I havent done the vette servo yet. Should I install a shift kit with the servo?
Old Nov 10, 2008 | 02:32 PM
BlackGMC's Avatar
Resident Retard
IMO, no, if you wanna post up your tune, i will take a look at it... Did you bump up your tranny pressures, lower your shift times, remove some/all TM, etc in the tune?
Old Nov 10, 2008 | 02:44 PM
dug's Avatar
dug
Banned
I had a shop tune it. not sure what they did. I had them remove 80% of the tm.
what does the transgo shift kit do?
Old Nov 10, 2008 | 02:45 PM
nighthawk08's Avatar
if you just want a quicker 1-2 shift, do the vette servo and see how you like it.
chevrolet all the way's Avatar
tm?? what is that. i believe a shift kit can be better than just a tune. if you only use the epc to change fluid pressure then you arent changin anything but the firmness of the shift. with a shift kit you can change how fast it shifts
Old Nov 10, 2008 | 03:15 PM
dug's Avatar
dug
Banned
yeah, Ive been meaning to do the servo for awhile. Whats the cheapest place to get one?
tm is short for torque management.
Old Nov 10, 2008 | 03:18 PM
thats whati was thinkin but wasnt sure... i can get em for around $20
Old Nov 10, 2008 | 04:02 PM
charcold-bowtie's Avatar
There pretty inverse of each other, both do about the same.
You can change shift times, pressure and other sutff in the tune as well.
Most built trannies call for stock shift pressure in the tune because they are raised mechanically in the trans....
Old Apr 1, 2009 | 01:59 PM
cams 98 silverado's Avatar
i dont mean to steal the thread... but this is exactly what i wanted to read... cuz im thinking of the transgo kit, i downloaded the install vid from the site and watched it a lot and seems like its fairly simple... but my truck is mostly stock(for now) an has 97982 miles on it... wondering if the transgo kit would work and if i would need the vette servo or not... buddy o mine did a transgo kit on a truck and he just did a kit and he said at good throttle it gets 1-2 chirp and sometimes 2-3 chirp. and when is it not worth doing a kit?
Old Apr 1, 2009 | 02:36 PM
D_reks{5.3}'s Avatar
Oregon performance transmission E B A Y FTW...all your trans parts needs and the best price you will find.
