Shackles on ex-cabs.
Old Jun 2, 2006 | 05:38 PM
99Silver6.0's Avatar
Default Shackles on ex-cabs.
Is there a big problem with running 2" shackles on an extend cab? I mean as far as driveline angle problems. Any more so after say a 4 wheeler gets tossed inthe back?
Old Jun 2, 2006 | 07:25 PM
kerryt1's Avatar
My last truck had 2" DJM shackles on the back, and they recommended a shim. I think the issue is with the 2 pc. carrier bearing type setup, but I haven't measured anything.
By the way, your trucking is f*ckin' sweet.
Old Jun 2, 2006 | 09:35 PM
usmcchevy's Avatar
No shims here and I havent had any problems except for, my exhaust hitting the axle every time I put somthing in the bed
Old Jun 2, 2006 | 09:46 PM
danjaimet's Avatar
Well, I have an 06 max EXcab 2wd with 20's and there is only 1.25" difference between the front wheelwell and the ground and the back. I know that a lot of people have put the 2" shackles on these trucks, but I don't want it to look like I have a load in the back. Any suggestions and am I just overreacting?!! I like the Belltech 2" shackles. Only 44.00
Old Jun 3, 2006 | 01:18 AM
you know, i woudl have said you can do it no problem without the shims but a couple weeks ago my carrier bearing broke on me and i was lucky to make it down the highway and to the mechanic without the driveshaft falling out. i have 2" leveling shackles and no shims for about 2 yrs and this was my first problem i dont know if its related or not. i did go "off-roading" that day, drove over a little curve because a gate was blocking the road to get out of school and it might have torqued the body and under stuff a little but who knows. anyways, where can i get some shimms and how hard is the install...
Old Jun 3, 2006 | 02:03 AM
RoosterMcCandles's Avatar
I have 2" DJM shackles and don't have any problems. Even loaded the bed down with bricks and didn't have any problems.
Old Jun 5, 2006 | 07:55 AM
silver-mod-o's Avatar
Hunt&Fisherator
I have shackles and hangers and I havent had any problems at all... a tiny vibration every once in a while while its loaded but nothing major at all...
Old Jun 5, 2006 | 08:24 AM
Nick™'s Avatar
you also have a torsion bar front suspension on a Vortec Max truck, so your front end has a range of adjustment available
Old Jun 5, 2006 | 08:42 AM
Superado's Avatar
11 Second Truck Club
Had them on my 2000 EC for about a year or so before Hotchkis TVS 2/4.
I didn't experience any problems.
Old Jun 5, 2006 | 03:02 PM
TouchOfEvil04's Avatar
I have a 4 "drop on my assend.2"shackles and 2"hangers.No problems...i get a slight vibration from like 20-28 then its gone.Other than that nothin.And the vibration is only there at full throttle.
