servo problems
Old Mar 29, 2008 | 05:35 PM
joeyc125's Avatar
11 Second Truck Club
Default servo problems
I just installed the vette servo, thought it went pretty easy, but now it has a wierd hesitation in the 1-2 shift and while in second with some throttle it surges like its slipping and grabbing. I drove it probably 5 miles and went easy on it first, then kicked it down and thats what happenned. I only let it happen once and drove it real easy the rest of the way home. so now im gonna goand hopefully someone will have some ideas.
Old Mar 29, 2008 | 07:31 PM
FLT's Avatar
FLT
FormerVendor
I would take it back apart to make sure that you did not cut one of the Teflon seals. Also make sure that you did not forget to install them. Vince
Old Mar 30, 2008 | 12:45 PM
joeyc125's Avatar
I took it apart again and checked everything and it looks to be right, i got all the rings on and they look ok. i drove it again and its still doing the same thing. 2-3 shift feels good and tight
Old Mar 30, 2008 | 02:24 PM
FLT's Avatar
FLT
FormerVendor
Did you swap over the metal 2-3 accumulator plate, springs and snap ring? These pieces are found in the 2nd servo facing the case when installed. If you have all the pieces in there I would suspect that you have a damaged band or something else going on. Is the servo the only piece that you changed or did you install a shift kit as well? How was the 1-2 shift before hand?
Old Mar 30, 2008 | 02:59 PM
joeyc125's Avatar
the 1-2 shift was kind of "loose" before but this isn't just the shift, the shift is worse than it was and when it is in second with more than half throttle, it wont hold, slips then grabs then slips, i just took it apart again and i am going to recheck, if that doesn't work going to put stock pieces back in, if its still bad, have feeling new trans may be in order. I want a converter anyways
Old Mar 30, 2008 | 05:02 PM
joeyc125's Avatar
got her fixed. The spring on the pin must of been getting cocked wrong i stuck it on there with a dab of vaseline and all is well. Thanks, Vince for your help, much appreciated!
Old Mar 30, 2008 | 10:06 PM
FLT's Avatar
FLT
FormerVendor
Excellent Joey! Glad to be of help in my free time! Vince
Old Mar 31, 2008 | 06:50 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Free time?!?! No such thing! Get back to work buddy!
madmann26
Apr 29, 2020 09:17 AM
Wolftrk99
Dec 3, 2015 08:12 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
