Service 4WD? WTF
Old May 19, 2010 | 01:58 PM
dhpro's Avatar
Default Service 4WD? WTF
I've had the unit serviced at the dealer just before warranty ran out for this exact problem, just had the rear seal replaced 2 weeks ago, and just changed both CV joints...I still get an intermittant msg...
I cant take it anymore...I leave the keys in the ignition all the time now!
Old May 19, 2010 | 02:02 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That message isn't for maintenance reminder, your truck has an electrical problem. On the '04 it is usually the t-case encoder motor sensor. You should scan for DTC's and post up, so we can tell you what should be done.
Old May 19, 2010 | 02:03 PM
dhpro's Avatar
YA...no scanner...I'll hook up the EFILive to it next chance I get...
Old May 19, 2010 | 02:05 PM
That should do it.
Old May 19, 2010 | 03:29 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I get one here and there....I just ignore it until I'm forced to replace something
Old May 19, 2010 | 04:24 PM
dewmanshu's Avatar
Moderately Differentiated
That seems to be the sentiment of anyone that surpasses 500HP. As long as nothing breaks (or for me...as long nothing keeps me from pressing the gas and making it go) let it go.
Yeah, what AKlowriderZ71 says, probably encoder motor sensor on the '04's. If you do yourself, don't be a normal for once, READ THE INSTRUCTIONS.
The earlier trucks popped that light a lot but it turned out to be the in dash switch was faulty.
Old May 20, 2010 | 06:49 AM
dhpro's Avatar
Thnx guys...I'm gonna change the other CV joint as its got a little "crunch" happening and take it from there.
I'm still thinking of leaving it in the Walmart lot with the keys in it, I'm just worried someone will strip it and leave the main bits behind!
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
RustyD
May 23, 2016 07:04 PM
Closer_2001
Sep 24, 2015 09:15 PM
