Separating Ball Joints
Old Mar 21, 2006 | 10:40 AM
NBred94's Avatar
Default Separating Ball Joints
I'm planning my lift spindle install, and from searching and looking at the front spindles, it appears that getting a puller on the upper ball joint is a no go. I have read that the best tactic is to use the BFH approach. Now I understand that there is a bit of technique required along with the brute force. Does anyone here know the right place to whack the spindle, and/or any other techniques to persuade the ball joints to let go of the spindle? If anyone had a pic showing where to hit, that would be cool too. Also, what are the chances of damaging the spindle with the aforementioned BFH?
Thanks
Old Mar 21, 2006 | 10:43 AM
NBred94's Avatar
Here's a pic if someone wants to draw an arrow or circle where to whack. Thanks.
Old Mar 21, 2006 | 10:48 AM
Injected1's Avatar
you can use a Ball Joint Separator...that is a BFH and a Fork...it works great...except when you cant find the BFH and have to use a sledge next to your new 3k$ paint job, that you spent months prepping the car for
Old Mar 21, 2006 | 10:53 AM
NBred94's Avatar
What are the odds of tearing up my grease boots with the pickle fork approach?
Old Mar 21, 2006 | 11:18 AM
03lowriderss's Avatar
it will tear
Old Mar 21, 2006 | 11:36 AM
NBred94's Avatar
Originally Posted by 03lowriderss
it will tear
That was the impression that I got from the searches that I did.
Old Mar 21, 2006 | 12:33 PM
Wilde Racing's Avatar
How do I change this text
I've never removed the ball joints or tierod ends from a new body style, but I have removed a ton at work. You allwas want to hit it at the boss, I find it easier some tomes to use two hammers, one resting on the boss and one to hit with, Allwas wear safty glasses!
Old Mar 21, 2006 | 01:48 PM
NBred94's Avatar
Thanks Wilde!
Old Mar 22, 2006 | 04:55 PM
Post
What's wrong with an air chisel? That's what I used on my 2000 Silverado's upper and lower balljoints. I didn't tear the boot either. It all ***** down to the chisel bit used and a nut placed on the end of the balljoint's threads that will need to be replaced with a new one (most of the time).
Good Luck!
Jim
Old Mar 23, 2006 | 10:01 PM
budhayes3's Avatar
PT's Slowest Truck
Try a BFH as mentioned first, and if it's really siezed, a carefully placed pickle fork will do the trick. I have a pickle fork attachment for my air chisel that works great. As far as hitting one hammer against another, I'd highly recommend against that. I used to use a similar method (with 2 hammers) to hammer hubs out of wheel bearings on Toyota's (the one hammer fit the hub perfectly). Well, I learned a long time ago that hitting two metals together of the same tensile will cause one to chip or shatter, but still used the 2 hammer method anyway. Long story short, one day I whacked the hammer, and one of them chipped about the size of a pea and shot into my left forearm like a slug from a .22. I needed surgery to have the chip removed, and ended up with a nice scar that is now hidden by a cool skull pirate tattoo. The doc said I was extrememly lucky the way the metal went in....it went deep and far, but didn't hit any nerves and didn't permanently damage any muscle.
Oh yea, and I totally agree with the safety goggles...I never used to use them either until the shot in the arm...but I learned a big lesson that day.
