Seeking input dropped kits for 2007 - 2013
Hey guys I appreciate the input. Beastmode did you have to notch or were you able to leave the frame alone? I want to do it right but i would rather not cut the frame.
Slammedslvy how big is the notch and which type of bags would you run? Would you run just bags or run air ride kit with compressor?
The helper bags are just a small bag setup that bolts to the frame and the top of the leaf spring near the axle. Not a full on bag suspension setup. I have done this setup on a couple trucks now and they work great and def help if you tow or use the bed of your truck. If your going to use them 24/7 to lift your truck to avoid the axle hitting the frame just get the appropriate drop like the 3/5 I posted earlier, your truck will ride smoother.
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
