Securing hose clamps?
Old Jul 14, 2007 | 10:00 AM
GMC_DUDE's Avatar
Default Securing hose clamps?
Long story short... Screw-type hose clamps that came with tranny cooler kit worked loose from vibration. Hose under pressure came off, spraying fluid all over engine bay and headers. Big smelly mess with lots of smoke, almost burnt the truck down (up?). Anyway what is a good way to keep these clamps from backing off like this (all 4 I checked were loose)? Search was no help. I could bend any excess band behind the screw, but is there a better way? Thanks.
Old Jul 14, 2007 | 10:14 AM
RoosterMcCandles's Avatar
Weird...I haven't had any problems with mine backing off or becoming loose. Were they on tight to begin with?
Old Jul 14, 2007 | 11:35 AM
truckmann's Avatar
I agree that sounds odd. I have never had a hose clamp come loose before.
Old Jul 14, 2007 | 12:18 PM
nonnieselman's Avatar
IVe never had a hose clampe do that either... and i have more than the average truck....
Old Jul 14, 2007 | 02:45 PM
kbracing96's Avatar
The hose clamp didn't come loose, the rubber compressed and relaxed. You need to check them from time to time to keep them tight.
Old Jul 14, 2007 | 04:14 PM
GMC_DUDE's Avatar
Thanks for the input. Yeah, seems there's more to the story. Not sure, but something smells fishy and it isn't the tranny fluid. Will post any discoveries.
Old Jul 14, 2007 | 05:51 PM
barley's Avatar
maby try one of them spring thpe hose clamps insted of the bandclamps
Old Jul 14, 2007 | 09:52 PM
Lord Aries's Avatar
I just make sure to check mine about once a month, usualy the trans lins have a little sepage by then...
Last time i was at a marine store they had mini T-Clamps, I should have bought some... Check your local marine store for some!
Old Jul 14, 2007 | 11:00 PM
GMC_DUDE's Avatar
Thanks Lord Aries. I may do that. I suspected (and still do somewhat, though I can't prove it) that the thermal bypass valve on the aftermarket cooler may have malfunctioned and cut off the fluid flow, thus causing the fitting to come undone due to excessive pressure. Some ballooning of the hose led me to suspect this. Anyway, because for safety reasons (happened in a dangerous place) I had to drive the truck with very little fluid for several miles, the tranny is now completely toast, with only 1st and 2nd gears, and barely those. More about this in another post later. AAARGHHHH!!!
Old Jul 15, 2007 | 02:22 AM
RedHot04's Avatar
Well, if the tranny is toast it doesn't matter much now, but the clamps you get for Fuel injection- fuel line are designed for high pressure might try those next time. Sorry about your trans.
