running a taller tire in the rear?
Old Aug 2, 2005 | 01:55 AM
LVSTOGOFST2002's Avatar
Default running a taller tire in the rear?
does this mess with abs bigtime? how do you get around it?
Old Aug 2, 2005 | 06:35 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
01thunder is running a much smaller tire in the front than he is on the back and it works fine for him.
Old Aug 2, 2005 | 12:31 PM
no abs issues? i've heard of some people that have to pull the fuse or something?
Old Aug 2, 2005 | 12:39 PM
ThunderZ28's Avatar
12 Second Club
negative...
I havnt had a problem as of yet..
been on there for 6 months or so.....
Old Aug 2, 2005 | 01:26 PM
any difference you anticipate with mine being an '04? i have traction control as well....... may that throw it for a loop?
Old Aug 2, 2005 | 02:18 PM
1slow01Z71's Avatar
I would think so since it uses input from the abs on a front to rear bias for tire speed is I believe how that works so it would mess with it pretty bad.
Old Aug 2, 2005 | 04:49 PM
ThunderZ28's Avatar
12 Second Club
hmmm.
wouldnt know about the traction control...I dont have traction control on mine
Tobad you dont live in my neck of the woulds.. I wuld let you borrow mine, and see if it would....
Old Aug 2, 2005 | 05:33 PM
well, i think i'm gonna throw the stockers on the rear, and see what happens. I'm running 275/40/18's all the way around, and i want 295/45/18's in the rear at least...
and maybe when i feel like spendin more, put them up front. but i derfinatly want them in the rear now, so i guess i'll just have to test it out.
Old Aug 2, 2005 | 09:20 PM
James B.'s Avatar
A subtle difference in tire diameter will not create problems.
You can cheat by setting up a fake rear end gear ratio but you have to manipulate everything just right so the speedometer stays correct.
For example, say you were programmed for 30" tires all the way around, have 3.42 gears, and swapped to a 28" up front and a 29" out back.
Stock this would be a total of 91929 pulses per mile with 3.42 gears and 30" tires. if you swap to 29" tires in the back the number of pulses per mile becomes 95076 pulses per mile, but that's for a 29" tire. Take that figure, make the tire diameter match whatever is on the front and then solve for the "virtual gear ratio" to make everything work.
Here's the math:
Start by finding out how many time the tire rotates in one mile:
D = Tire diameter
G = Gear Ratio
M = 5280 (feet in a mile)
P = Pulses per mile
pi = 3.14
T = Tire Revolutions per mile
T = M / ( ( D * pi ) / 12 )
so,
for 30" tire, 5280/((30*3.14)/12) = 672 revs per mile
for 29" tire, 5280/((29*3.14)/12) = 695 revs per mile
for 28" tire, 5280/((28*3.14)/12) = 720 revs per mile
The reluctor ring on the tailshaft has 40 segments meaning it pulses 40 times per revolution.
Therefore, P = G * T * 40
For the 30" tire and 3.42 gear combination mentioned above, 3.42*672*40 = 91929 Pulses per mile
For the 29" tire in the back it's 3.42*695*40 = 95076 Pulses per mile
Back to the example of 28" up front vs. 29" in the back, take the real pulses per mile figure for the rear tire and solve for the "fake" gear ratio using the "T" factor for the front tire:
G = P / 40 / T
95076/720/40 = 3.30
When programming the PCM use the pulses per mile number for the front tire and the real gear ratio. (98496 in this example) This will be off from the real number but the difference in gear ratio will correct it and ABS and traction control will function as they should.
Like any formula it gets more accurate the more decimals you choose to use for calculations and pi.
Get it?
I run smaller rims AND tires on the front of my Tahoe with no problems with ABS or VSS.
Here's a picture:
Old Aug 4, 2005 | 11:39 PM
James B.'s Avatar
It's almost two days later and no replies? It took me a while to figure this out initially which is why I share it as a REAL solution. No comments?
