Rotor's
Old Jan 11, 2005 | 10:22 PM
4.8redchev's Avatar
Default Rotor's
anyone have any trouble with the rear single piston calipers? mine sound like they are rubbing whenever i drive.Is there any just new rotor's i could buy? maybe like some crossed drilled or anything like that? i think i might convert the caliper to the dual piston.
Old Jan 11, 2005 | 11:04 PM
JSmith's Avatar
Sounds like your rear caliper is frozen. Pull your rear wheels off and check your pads. Chances are the inside pad is wearing faster than your outside. You can also rebuild your calipers with a GM caliper kit but need to be carefull when removing the piston and also during re-install as so not to destroy your o-rings.
Old Jan 11, 2005 | 11:29 PM
BlownChevy's Avatar
blownerator
25 Year Member
you might want to check the parking brake pads too!!!
Old Jan 11, 2005 | 11:50 PM
desTRUCKtive's Avatar
Dont you need to re adjust the parking brake as well, I heard that can do a number on your brakes.
Old Jan 12, 2005 | 12:28 AM
JSmith's Avatar
Crap, forgot to mention that! Mine were ok when I had my rotors off.
Old Jan 12, 2005 | 05:31 PM
4.8redchev's Avatar
well my dad's friend owns a brake shop and i called him and he said that the single piston calipers are the only chevy brakes that give them problems just a freak thing.he said the best thing to do is to convert it to a dual rear piston caliper.have the change the mounting brackets and a few other things.also is there any rotors out there that are worth a look? like power slot etc.
Old Jan 12, 2005 | 08:08 PM
budhayes3's Avatar
PT's Slowest Truck
I had a similar problem with my 99, turned out to be the parking brake shoe had shifted in the right rear due to a busted retaining clip...it's pretty common on these trucks. There's a TSB on it:
Brakes - Scraping Noises From Rear of Vehicle
File In Section: 05 - Brakes
Bulletin No.: 02-05-26-002A
Date: February, 2003
TECHNICAL
Subject:
Scraping Noise From Rear Of Vehicle
(Replace Parking Brake Shoe Kit and Clean Drum In Hat Rotor)
Models:
2002-2003 Cadillac Escalade, Escalade EXT
1999-2003 Chevrolet Silverado 1500 Series Pickups
2000-2003 Chevrolet Suburban, Tahoe 1500 Series Models
2002-2003 Chevrolet Avalanche 1500 Series Models
1999-2003 GMC Sierra 1500 Series Pickups
2000-2003 GMC Yukon, Yukon XL 1500 Series Models
This bulletin is being revised to add Suburban and Yukon XL models. Please discard Corporate Bulletin Number 02-05-26-002 (Section 05 - Brakes).
Condition
Some customers may comment on a scraping noise from the rear of the vehicle while driving. The noise may be intermittent.
Cause
Condition may due to the parking brake shoe contacting the drum in hat rotor without the parking brake being applied, causing premature wear on the shoe lining.
Correction
Replace the parking brake shoe and install a new designed spring clip retainer. Follow the service procedure below to correct this condition.
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information sub-section of the Service Information (SI Document ID # 639546).
2. Remove the tire and the wheel. Refer to Tire and Wheel Removal and Installation in the Tires and Wheels sub-section of the Service Information (SI Document ID # 656965).
3. Relieve the tension on the park brake cables by loosening the nut at the equalizer.
4. Mark the relationship of the rotor to the hub.
5. Remove the brake caliper bracket mounting bolts.
Notice : Support the brake caliper with heavy mechanic's wire, or equivalent, whenever it is separated from it's mount and the hydraulic flexible brake hose is still connected. Failure to support the caliper in this manner will cause the flexible brake hose to bear the weight of the caliper, which may cause damage to the brake hose and in turn may cause a brake fluid leak.
6. Remove the brake caliper and brake caliper bracket as an assembly and support with heavy mechanic's wire or equivalent. DO NOT disconnect the hydraulic brake flexible hose from the caliper.
7. Remove the rotor retaining push nuts from the wheel studs (if applicable).
Notice: DO NOT use a hammer to remove the rotor from the hub; it may cause damage to the rotor.
Important :The rotor may not be easily removed from the hub due to a rust build up on the outside edge of the drum and hat portion of the rotor.
8. Remove the rotor from the hub. If the rotor cannot be removed from the hub by pulling on the rotor, use J 46277 rotor removal tool.
Notice: Place J 46277 between the rotor surfaces in the vent section of the rotor. DO NOT place J 46277 on the back side of the rotor surface, it may damage the rotor surface.
9. Using removal tool J 46277 on slide hammer J 6125B, remove the rotor by placing removal tool J 46277 in the vent section of the rotor at the twelve, three, six and nine o'clock positions, not necessarily in that order.
10. Clean the rust ridge from the drum portion of the rotor using a grinding stone and rotor resurfacing kit J 41013.
11. Remove the spring clip bolt (3) and retainer (2) and discard.
Important :Minimum thickness of the parking brake shoe lining in any given spot is 1.5 mm (0.06 in).
12. Measure the parking brake shoe thickness in multiple spots. Replace the parking brake shoe if the thickness is less than 1.5 mm (0.06 in). Continue with Step 14.
13. If the parking brake shoe lining is greater than 1.5 mm (0.06 in), continue with Step 19.
14. Rotate the parking brake shoe (1) out from the bottom and pull it out of the adjuster. Discard the shoe.
15. Remove the park brake shoe assembly from the vehicle by placing one of the open ends of the shoe over the axle flange and rotate the shoe until it has cleared the flange.
16. Turn the adjustment screw (1) to the fully home position in the notched adjustment nut.
17. Install the new park brake shoe assembly (1) from the parking brake shoe kit, P/N 88982875, to the vehicle by placing one of the open ends of the shoe over the axle flange and rotating the shoe until it is behind the flange.
18. Slide the shoe into the adjuster and position the shoe to the backing plate. Install the retaining spring clip (2) and bolt (3) from the parking brake shoe kit, P/N 88982875. If using parking brake service kit 88982875, SKIP Step 19.
19. Replace the retaining spring clip (2) and bolt (3) from the parking brake retaining spring clip kit, P/N 88982879.
Tighten
Tighten the bolt (3) to 5 N.m (44 lb in).
20. Set the J 21177-A so that it contacts the inside diameter of the rotor.
21. Position the J 21177-A over the shoe and the lining at the widest point.
Important :
^ The parking brake adjustment screw threads should not exceed 5 mm (0.2 in) of exposed thread.
^ The clearance between the park brake shoe and the rotor is 0.6604 mm (0.026 in).
22. The parking brake adjustment screw threads should not exceed 5 mm (0.2 inch) of exposed thread.
Notice : Whenever the brake rotor has been separated from the wheel bearing flange, clean any rust or foreign material from the mating surface of the rotor and flange with the J 42450 hub cleaning kit. Failure to do this may result in increased lateral runout of the rotor and brake pulsation.
23. Use the J 42450-A to clean all rust and contaminants from the mating surface of the hub flange.
24. Use the J 41013 to clean all rust and contaminants from the inside diameter of the hat section of the brake rotor to prevent any foreign material from getting between the brake rotor and the hub flange.
25. Align the mark on the rotor with the mark on the hub and install the rotor by slowly turning the rotor while pushing the rotor towards the axle.
26. Install the caliper and the bracket as an assembly to the vehicle.
27. Perform the following procedure before installing the caliper bracket mounting bolts.
^ Remove all traces of the original adhesive.
^ Clean the threads of the bolt with brake parts cleaner, P/N 12346139 (Canadian P/N 10953463), and allow to dry.
^ Apply threadlocker, GM P/N 12345493 (Canadian P/N 10953488), or Red LOCTITE(TM) # 272, to the threads of the bolt.
Notice :Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
28. Install the caliper bracket mounting bolts.
Tighten
Tighten the brake caliper bracket mounting bolts to 175 N.m (129 lb ft).
29. Repeat this procedure on the other side of the vehicle.
30. Tighten the nut to the intermediate cable at the equalizer.
Tighten
Tighten the nut to 3.5 N.m (31 lb in).
31. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in the Tires and Wheels sub-section of the Service Information (SI Document ID # 656965).
32. Lower the vehicle.
33. Verify that the self adjuster lock-out pin has been removed.
34. Fully apply and release the park brake pedal three times.
Old Jan 12, 2005 | 08:44 PM
4.8redchev's Avatar
whoa,thanks alot but i think im just going to go with the dual piston im not paying for it so might as well do it.thanks alot though i appreciate it.also anyone know some good rotor's to go with? and maybe some new pads? like hawk's or somethin?
Old Jan 12, 2005 | 09:28 PM
facn8me's Avatar
I think people are trying to help you fix your problem. The new brake conversion sounds great. But at least check the parking brake shoes as they are a source of the noise on 90% of cases like yours. would suck to do the calipers and have the same noise.
Old Jan 12, 2005 | 09:38 PM
KeukaZ71's Avatar
my rear calipers were sticking due to alot of offroad activity. mud would accumulate on the brakes and calipers. here are some pics of the pad on one side being worn down to the metal
plus the rotor was in pretty bad shape.
