Ridetech Coil-overs Installed gmt-800
Old Jun 24, 2013 | 07:30 PM
  #51
TheBeeblebrox's Avatar
Originally Posted by texasglock23
This was his response when I asked him your question.
"They don't make anything above a 800lb spring in a 10". The 8" spring has more options all the way up to 1200lb. There is no ride quality difference between a 8" or a 10". I've tested many combos.
He didn't look hard enough, they make the 10" up to 900#
<ss:value source="$page.title"/>
The way I looked at it and for my set-up the 10" was the preferred length that would put the shock travel in the 'sweet spot' so-to-say, and I don't have any experience with the 8" so I guess I don't have much to go on just my opinion.
Originally Posted by GMCtrk
I'm way behind the curve here, but what's the advance of these over the stock coils aside from the fact their adjustable and weigh less?
Basically what you said plus getting better shock travel, more shock travel = better ride.
And ditching sprung/un-spring weight is always a good thing with these heavy *** trucks
Old Jun 24, 2013 | 07:46 PM
  #52
texasglock23's Avatar
I didn't check, just copied and pasted.
Old Jun 24, 2013 | 08:16 PM
  #53
Didn't check what? I'm confused
What I was getting at was that He (the one that told you they didn't go past 800) didn't do his research thoroughly on the different spring rates.
Old Jun 24, 2013 | 08:46 PM
  #54
Chevy_King1500's Avatar
maybe I missed it, but could you share your full front end specs.
I'm looking to get these but would only want say a 2" drop in the front from stock ride height.
Old Jun 24, 2013 | 08:48 PM
  #55
Check the springs length and spring rate from what he posted.
I'll post of my thoughts and results once I get these on.
Old Jun 24, 2013 | 09:11 PM
  #56
Sure no problem
Right now I'm lowered 5" with the Coil-overs and Mcgaughy's 16"+ drop Spindles
So with stock spindles and the same Coil-overs it would be a 3" drop and you would be able to crank them up to 2", BUT it could possibly 'top out' if you go too far up, as it is close to the full extended length of the shock.
Ok gotcha, not trying to come off on the wrong foot here, just trying to help as much as possible.
Old Jun 24, 2013 | 09:22 PM
  #57
No offense taken, this is an educational thread, all info needs to be posted, rather opinion or fact, will help others in the future. I only take his word because he has done several builds for people, but I've always heard the longer the shock and spring you can run the better your ride would be, at least in theory.
Old Jun 24, 2013 | 09:28 PM
  #58
Exactly, that's the reason I started this thread!
And thats the same school of thought I use too, and from what I've read over the net and experienced myself, it seems to support that theory.
Old Jun 24, 2013 | 09:56 PM
  #59
Agreed, thanks for all the help so far!
Old Jun 25, 2013 | 02:57 PM
  #60
I may have missed it, but did you use stock bolts or drill out and go bigger? From a glance they look oem size.
