Reverse lights not working
Old Oct 17, 2006 | 01:03 PM
thunder550's Avatar
High on diesel fumes
Default Reverse lights not working
Where is the switch for this? In the steering column or in the trans? Or is it just a blown fuse?
Old Oct 17, 2006 | 02:16 PM
Bowtie70SS's Avatar
The switch is located on the gear selector shaft on the transmission. If you replace it take a heat gun to the weatherpack connectors for a few seconds. I did not when I took my trans out and I ended up buying a $50 switch from the dealer.
Dave
Old Oct 18, 2006 | 10:50 PM
thunder550's Avatar
So it's the electronic thingy that bolts to the side of the trans....great....I had an extra one that I just sold
Old Oct 19, 2006 | 10:08 AM
vanillagorilla's Avatar
Check the bulbs and fuses first. The two wires that make the lights light up when the switch (electronic thingy) is in reverse are a pink and a green. There's more than one pink I believe, but you could back probe them to test the switch to see if it's completing the circuit.
ARC
57
Feb 21, 2022 10:54 AM
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
MileHighSierra
Jul 12, 2015 12:23 AM
