Removing Dowl pins
Old Sep 20, 2006 | 07:39 PM
Zick's Avatar
Have you tried heating up around the pin?
Old Sep 20, 2006 | 08:16 PM
RPOWU8's Avatar
11 Second Club
Heat it up a little around the pin with a propane torch and remove with pliers. Try not to heat the pin, should come loose right away.
Dee Jay
Old Sep 20, 2006 | 08:19 PM
litreddevil's Avatar
Banned
put some oil on them then the tap them in a little then it will brake the seal then u will be able to pull them out
Old Sep 20, 2006 | 08:58 PM
LesPaul's Avatar
yeah.... i dont think pulling them is going to work..... i have to go tomarow to fill up my propane tank and im going to try that....
Old Sep 20, 2006 | 10:39 PM
m7 rocket's Avatar
Or you could buy a dowel removing tool from Snap On or whomever. Mine works great. It just grips the dowel and you use a slide hammer on it. Never fails.
Heating the housing is probably the best to help though as it expands the housing. Good luck.
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
