Rear shock angle
Old Nov 30, 2013 | 08:06 PM
53bowtie's Avatar
Sorry to dig this thread back up, just wondering if this configuration worked out well for you?? I am looking at relocating shocks and doing adjustables in the rear over the winter to try to improve traction come next spring. Thanks!
Old Nov 30, 2013 | 08:12 PM
BlackGMC's Avatar
Resident Retard
I have done both on my truck. Straight up and angled. The angled ride a little bit better. Also your really limited on the length you can run when they are straight up. With mine angled now i run stock length shocks.
Old Nov 30, 2013 | 11:29 PM
53bowtie's Avatar
Are yours angled 10 degrees or some other amount? Also, if I welded adjustable mounts to the axle that would allow me to play around a bit with the angle of the shock given a fixed top mount. Would this be worth it or is there not enough difference in say 10 degrees and 15 degrees for it to matter?
Old Dec 1, 2013 | 02:41 AM
BlackGMC's Avatar
Resident Retard
In my opinion the length is what you should be concerned with. The angle for what our trucks are used for is less important.
Old Dec 1, 2013 | 08:56 AM
TXsilverado's Avatar
if straight line performance is your only concern, i'd do an adjustable bracket on the axle. the difference between 5* and 15* probably won't be noticed with a good adjustable shock. on a stock shock location lowered they can lay out way beyond 45*.
I say adjustable bracket because you can set it for track conditions, then once finished, put them back to street duty. on the track you only need around 1" of compression and as much extension as you can get.
only 1" compression on the street would be harsh, and would probably end up damaging a shock. for my build, i'm guna try and go in the middle if I can. I want 2" compression and hopefully around 5" extension. it's a weekend toy though, and a lot lighter than a silverado. I would shoot for a middle ground on a daily setup
Gadgetized
Aug 21, 2020 03:14 PM
GXPJAY
Nov 5, 2015 06:49 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
1bad2k
Aug 18, 2015 09:50 PM
121
Jul 16, 2015 12:18 AM
