Rear Drum to Disc conversion
Old Oct 7, 2007 | 11:28 AM
06RSTMAN's Avatar
Default Rear Drum to Disc conversion
I was pondering the idea to convert my 06 silverados rear drum set up to the disc setup GM had a few years ago. I was wondering was there any problems that people where having with this and that is why GM went back to drum. Or was it just cost effective to put drums on the rear. I thought about going to the junk yard and getting these parts. What parts do I even need to convert it over? All suggestions are welcome.
Old Oct 7, 2007 | 11:31 AM
nightrunner's Avatar
Mr. Obvious
the reason gm swapped from discs to drums is because some were complaining about the rear discs/pads squealing sometimes and it was cost-efficient for GM to swap to drums and have no warranty issues than to fix the squealing under warranty
Old Oct 7, 2007 | 02:09 PM
06RSTMAN's Avatar
So should I rule out converting to GM discs and spend the big $$$ for aftermarket. What about getting the brackets and other hardware and just upgrading the calipers and rotors. This would work wouldn't it?
Old Oct 7, 2007 | 04:35 PM
Mr. Obvious
i cant believe that regency didn't swap to discs when they put the alumasports on the RSTs.
anyways, if you want the front to match the rears, get a set of rear alumasports and see what it doesnt have and get the stock parts to make it work. IMO
Old Oct 7, 2007 | 04:45 PM
skyhighsami's Avatar
no title here
SSBC just came out with a rear deisc conversion if I am not mistaken. I thought that the RST trucks had the SSBC Force 10 up front and I bet that the rear upgrade was an option.
Old Oct 7, 2007 | 09:28 PM
terravast4's Avatar
if you are ever planning on running slicks for the track I would not use the alumasports as you are limiter to a 20" rim or more. I was gonna make the rear conversion and am glad I didn't.
Old Oct 7, 2007 | 09:31 PM
Quik's Avatar
5 year bitches!
if your run stock 10 bolt brakes you can run 16" if you grind you can run 15s
Old Oct 8, 2007 | 01:56 AM
sickness81's Avatar
Registered User
I don't mean to thread jack but i was looking to do the same. Ive checked out SSBC and they don't have a rear conversion kit for the 06, unless im mistaken.
Old Oct 8, 2007 | 05:29 AM
Quik's Avatar
5 year bitches!
just look for parts from the pre-05 trucks
Corvette454l88
Sep 1, 2016 01:24 AM
chopperloco
Jul 10, 2016 10:45 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
mrgrim
Jul 8, 2015 08:12 AM
