rear disc brake swap
Old Feb 21, 2009 | 11:54 AM
$nake Charmer's Avatar
Default rear disc brake swap
i recently purchased an 03 RCSB that had been totaled but had a very hot motor/TC/tranny/exhaust etc... it also has rear disc brakes... mine doesnt... how do you convert??? remember the wrecked truck has no rear end gears and the axles are a little bent...
Old Feb 21, 2009 | 12:00 PM
95 bright teal's Avatar
Do you plan on upgrading the rear rotor/caliper setup or running stock?
are your front brakes stock?
Old Feb 21, 2009 | 12:01 PM
laynlow77's Avatar
just take the axles out of both trucks so you can the backing plates and everything off. then swap it all over! you dont need to do a proportioning valve or anything....
Old Feb 21, 2009 | 12:21 PM
yes im gonna stay with factory rear discs for now money is running low for now... yes my fronts are disc. and i cant use the axles on the other truck...
Old Feb 21, 2009 | 03:06 PM
budhayes3's Avatar
PT's Slowest Truck
You don't need to swap the axles, just remove them to gain access to the backing plates that you'll need for the disc setup
5.3Okasai
Mar 9, 2022 01:07 PM
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
Bluchevypick
Aug 18, 2015 09:11 AM
mrgrim
Jul 8, 2015 08:12 AM
