rear diff fluid
im fixin to pull the cover off my rear diff to check some things. what fluid are you guys puttin back in there? what brand? 75w-90 synthetic is what the book calls for. its goin to be for the truck in sig..
Thanks..
Thanks..
new gasket? what if i used some "gasket maker"? the black stuff.
from my other post, about the annoying sound that my truck is making. im thinkin its comin from my rear diff? or axle bearings? but i just wasted the $165 on a front right hub that i thought the noise was comin from... THIS IS GETTING OLD FAST... and im goin to go ahead and get some new ujoints while im replacing stuff.... Wish Me Luck!!
and i think the noise is gettin worse?? how can i tell that the axle bearings are goin out? any suggestions? it they arent too expensive im goin to go ahead and slap them in.. now would be a good time to put some lower gears and a better locker or lsd.. Yea I Wish!!
. . . but i just wasted the $165 on a front right hub that i thought the noise was comin from...
I use RedLine SuperLight ShockProof Diff fluid:
(http://www.redlineoil.com/products_g...D=20&prodID=61)
The shop I took my truck to put in some Kendal 85w90, I have about 80 passes in the 1/4 mile on that, everything is good to go
http://www.kendallmotoroil.com/NR/rd.../K_All_Oil.pdf
