Rear Axle Assembly Swap
Old Nov 1, 2012 | 11:44 AM
NeedMoTools55's Avatar
Registered User
Default Rear Axle Assembly Swap
On a 95 Silverado std box 4x4 I am replacing a blown out rear differential ( open diff) assy with another unit that has the same ratio but with a locker (closed diff). Will this change the pinion position , or more specifically the drive shaft length ?? Will the locker have the same issue with the C clip coming out allowing the cross pin to come out and bind with the carrier ?? What is the most effective way to mod or prevent this.
Thanks,
5.3Okasai
Mar 9, 2022 01:07 PM
lsxperformance
Feb 2, 2020 01:07 AM
thunder550
Oct 8, 2015 04:53 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Mike454SS
Jul 20, 2015 08:52 PM
