rear anti sway bar
Old Jun 28, 2009 | 07:23 PM
OLDPOS's Avatar
Default rear anti sway bar
Can it be used as or with traction bars? Are there any negative side effects with a rear sway bar?
Old Jun 28, 2009 | 07:37 PM
02BlueStepside's Avatar
I can't think of any problems using both. The sway bar alone is not going to help with straight line traction though so it cannot be used as traction bars. It will help the rear stay planted in corners though.
Old Jun 28, 2009 | 08:53 PM
PathfinderJr's Avatar
with the amount of understeer these heavy pigs have, even if lowered, a rear sway bar is only gonna help matters. I highly doubt one could even stiffen the rear up enough on these trucks to induce oversteer without judicious application of the throttle.
Old Jun 29, 2009 | 03:07 PM
454navyss's Avatar
traction bars usually bolt to the springs and frame in front of the rear axle, a sway bar bolts to the axle and the frame behind the rear axle so they should work together with no problems
Old Jun 29, 2009 | 03:53 PM
shakesvho's Avatar
You can do it I have Hotchkis Performance Front And Rear Sway Bars #2231 and a set of Calvert CalTrac Bars #3400. no problems
chopperloco
Jul 10, 2016 10:45 PM
GXPJAY
Nov 5, 2015 06:49 AM
DONTH8
Jul 26, 2015 06:59 PM
Ketis
Jul 23, 2015 12:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
