Re gearing after 4l80e swap
Old Apr 29, 2015 | 09:20 PM
1bad2k's Avatar
Well i checked my rpo codes, and got under the truck and spun the driveshaft and counted as the tire spun, it was just under 3 and a half revoltuions, so that would def be 3.42s. I do plan on a converter. I am considering the circle d billet 258mm 2800rpm, but i know a lot of trucks come with 4.10s as do all awd SSS'. I run the truck in "auto 4x4" so im not too very concerned about just blasting the tires off. I have a couple 149 transfer cases sitting so that will be the end result anyways.
Old Apr 29, 2015 | 09:24 PM
1bad2k's Avatar
actually, something that's bothering me even worse at the moment, I'm having a problem that I've seen other people have about the shifter not feeling right. It seemed like the shifter cable was too short, even after I bought the 4l80e shifter bracket. the shifter feels very sloppy, and you can't put it all the way and down to manual first. Anyone know what I did wrong?
Old Apr 29, 2015 | 09:53 PM
GMCtrk's Avatar
There is an adjuster for the cable I believe.
Old Apr 29, 2015 | 10:05 PM
1bad2k's Avatar
Yeah, it is already adjusted all the way out
Old Apr 29, 2015 | 10:16 PM
GMCtrk's Avatar
Did you adjust your neutral safety switch properly?
Old Apr 29, 2015 | 10:44 PM
1bad2k's Avatar
probably not, I never saw anything on how to do that. Is there a write up somewhere that you know of?
Old Apr 29, 2015 | 10:59 PM
GMCtrk's Avatar
theres a little metal alignment pin thats fits onto the nss
Old Apr 29, 2015 | 11:21 PM
1bad2k's Avatar
Hmm, I'm gonna get the truck out this weekend and look at that.
Old Apr 30, 2015 | 12:21 AM
1bad2k's Avatar
Found some instructions Bear posted before to adjust it. Gonna do that tomorrow. Hopefully that will fix that issue.
lycominghunter
Jul 29, 2015 04:24 PM
iregret
Jul 27, 2015 10:32 PM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
NuckenFuts
Jul 9, 2015 08:45 AM
