question: performance + leaf springs
Old Jun 12, 2012 | 11:58 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Are you sure its not the front end??? Like loose wheel hubs or bad inner / outer tierods
Whats been done to your rear differential??? Open, Locker, or Posi differential???
Old Jun 13, 2012 | 05:44 AM
TXSZ66AVLANCHE's Avatar
The steering is tight, pretty sure the problem is not in the front end. Rear diff was open, now has a truetrac. The swaying started well after the tt was installed, made sure both wheels are getting power by leaving a nice set of twin stripes on the road
Old Jun 13, 2012 | 11:23 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is it swaying with your street tires, or your track tires? Or both sets? Are the track tires radial or bias?
I'd like to see a printout of the wheel alignment if you can post it up. That could show a problem if there is one with steering/suspension geometry. There's other things to check also, like set-back, worn parts, cracked leafs, etc.
Old Jun 14, 2012 | 05:47 AM
Only street tires, no track tires yet.
Old Jun 14, 2012 | 11:19 AM
1FastBrick's Avatar
It is possible that the rear end is not centered in the rear and your fighting it under load. You would have to separate the leafs from the axle and check the pins.
Do you know the history on the vehicle? I.e. if it was ever wrecked or possibly abused in the past???
Old Jun 14, 2012 | 11:59 AM
Carfax showed one owner in San Antonio since New, also listed as a new vehicle trade in. Serviced and state inspected from same selling dealer since new.
Old Jun 14, 2012 | 07:28 PM
Wide Open's Avatar
You have a chance to get it on the alignment rack yet?
southernsmoker
Aug 31, 2015 03:09 PM
nickpc82
Aug 10, 2015 09:08 AM
signguy62
Jul 27, 2015 03:42 PM
lxcoupe
Jul 24, 2015 06:01 PM
Mike454SS
Jul 20, 2015 08:52 PM
