Qa1 question
Old Feb 19, 2013 | 09:56 PM
lglowe's Avatar
Default Qa1 question
Looking to pull the trigger on a set of qa1 12 way adj. for the front of my 2wd 2002 Silverado. I'm currently running 2" lca's on the front. I've done a lot of reading and I just won't to see if you guys think about the setup that speed engineering sells for our trucks. Is this what I need to get them on?
Links to the shocks
QA1 Motorsports TC1958P - QA1 Front 12-Way Adjustable Shock (Stock Or 4 Inch Drop) | Speed Engineering
QA1 Motorsports BAR350K - QA1 T-Bar Conversion (Required To Fit Late Model Trucks) | Speed Engineering
Old Feb 19, 2013 | 10:30 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Man I wish they made something like this for nnbs. Dont like the way my belltechs ride. I think thats all. You will need to drill the lower nuts out and use bigger bolts and nuts if im not mistaken.
Old Feb 20, 2013 | 07:02 PM
UnVmy5.3's Avatar
First I've heard of this. But says they don't work with springs
Old Feb 21, 2013 | 08:21 PM
lglowe's Avatar
Bump. Can anyone that runs these shocks confirm that these are the ones I need?
Old Feb 22, 2013 | 05:24 AM
blown02408's Avatar
02 w/ lowest mileage 2800
I think the extended length is a little short, stock is something like 14.5-14.7". I believe they would work well for someone running 1 or 2" drop springs though.
Old Feb 22, 2013 | 08:51 AM
lglowe's Avatar
Can you give me a part number on ones that would work with the control arms I'm running?
Old Feb 22, 2013 | 10:03 PM
blown02408's Avatar
The shocks above will work, but will probably hurt more than help at the track due to the lack of extension. The t-bar can be mounted above the a-arm to gain back some extra travel. The next size up that qa1 sells has 15.5" extension and is part number ts502, td502, or tr502 depending on adjustability. You'll need the 3.5" t- bar kit.
JordanH
Dec 25, 2015 08:32 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
