put in stall, now won't lockup at highway speed
Old Nov 6, 2008 | 01:26 AM
RotaryResurrection's Avatar
Default put in stall, now won't lockup at highway speed
Last week I put in the stall I have had on the shelf for a long time. It is a used yank tt2600 that I got from a member here.
I have an 02 yukon denali awd, stock trans/pcm. I do have a big B&M 13x10 trans cooler.
I drove it around town for a couple days and all seemed normal. Lockup characteristics seemed normal as well, although I never got above about 55-60mph.
Couple of days ago I had to take a road trip about 300 miles away and tow a car back, something I've done many times with this truck.
On the way down (unloaded) I noticed the converter would not want to lock up at highway speed, 70-80. I rode for 20-30 miles at a time and it would not lock. Obviously the trans would heat up as time went on, but it never got over about 200. If I slowed down to around 60mph for a couple of minutes, it would eventually lock up (it was hard to tell when exactly it happened since I was watching the traffic I was behind).
Once it was locked, it tended to want to stay locked without a considerable amount of additional throttle...maybe a bit more than I usually have to apply to unlock it, or maybe it just seems that way because i am getting used to the response of the new converter? It would stay locked up for 20-30 miles and the trans temp would come down to 140, and then randomly unlock again for 20-30 more miles and it would slowly rise to 200. It seemed to unlock when I had to let off the throttle totally to decelerate for traffic or going down a grade.
On the way back, in tow/haul mode towing the car, it acted the same, but was even harder to get it to lock up. The trans never got over about 230 before I was finally able to slow down to 55 for a while and get it to lock up, then it would stay that way until it cooled back down to 150, then it would unlock again and stay that way for a long time.
When I got close to home, I switched tow/haul back off while still towing, and the lockup seemed to be working more normally. In fact it would lock up and not want to come unlocked until I gave it enough throttle to kick into 3rd gear. Then when I let it go back into 4th, it would lock up within a couple of seconds and stay.
From what I have read, there are a couple of possibilities:
1) something is wrong with the lockup clutch in the converter, which could cause damage to the transmission as well.
2) the pcm needs a tune to redefine the lockup speed settings.
Or perhaps the PCM needed all that time at highway speed to "learn" the new lockup characteristics? Doubtful, but I figured I would throw it out there.
Also, I've read that a shift kit/servo should be installed with a stall. I guess the WOT shifts seem slightly softer with this stall, but nothing to write home about. I wouldnt mind installing a shift kit IF I were assured that the truck would not shift like a corvette in traffic. I tow stuff and haul the family around in the truck and want to maintain the luxury truck feel. Anyone have input on that subject?
Thanks in advance.
Old Nov 6, 2008 | 01:33 AM
1989k1500's Avatar
You need a shift kit and tune IMO.
The shift kit Id do with any aftermarket converter, or even a stock one for that matter.
Oobray
Jun 13, 2022 03:38 AM
rednekferlife101
32
Jan 8, 2016 10:42 PM
thunder550
Oct 8, 2015 04:53 PM
Sales4@Texas-Speed
Aug 3, 2015 03:57 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
