Project LOW71
Old Jan 1, 2011 | 06:52 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by 1Bear
I wouldn’t expect that you would notice too much of a ride penalty, as you’ve basically done what GM did to lower the SS and Denali trucks outside the installation of the Belltech 2” drop shackles. Just for reference, GM removed the rear lift blocks on the SS, but left them installed on the Sierra Denali & C³’s and as such each had their own ride height. You may have done it and just didn’t add it to your write-up, but if not, something that you also may want to do is remove the rear snubber extension brackets and mount the rubber snubbers directly to the frame rails to prevent early bottoming out. It will give you an extra 1.5/16” of clearance. Another item that can improve handling and ride somewhat is the installation of the front snubbers from an SS. This is an item you would just have to check out the part numbers for your particular truck, as while on the earlier 4WD’s, the parts were specific between the two, GM appears to later installed the SS style pieces on the regular 4WD’s as well. You can do a quick check without getting into looking up part numbers by just checking out the appearance of what you have installed on your truck. The SS pieces are just black rubber, while the older style 4WD pieces were a yellow-ish rubber. The stock SS Bump-Stop’s are part # 15161761 for both sides.
Here is a comparison shot between the two. Ignore the difference from one part being used.
You could also replace the factory jounce bumpers with Belltech 4923 bump-stop’s. They are a little shorter and softer than the factory pieces.
If you do find you want different pieces, Belltech has the part numbers below.
4922 – 1.26” tall x 2.5” O.D.
4923 – 2” tall x 2.5” O.D.
4924 – 3” tall x 2.5” O.D.
I replaced my Z71 front bumpstops with the rubber SS bumpstops...the Z71 bumpstops were made of a harder rubber than the SS ones, and not everyone knows that the bumpstops actually work to cushion the suspension and will have an effect on ride quality and spring rate. I had to cut the bumpstops also once I lowered it...they should be just touching the lower control arm with the truck at rest on a level surface
Old Jan 1, 2011 | 08:08 PM
LS1DIME's Avatar
Well the alignment was actually pretty easy, the passenger side is all the turned to the outer most postion but it is right on spec, the driver side aligned with a little left available, as for the bumpstops i just cut like 3/4 of them off front and rear! As for the lowered 4x4 to each is his own! Its covered in mud right now, we went out on some log trails today and had a ball and had no issues stayin right with my buddies and their stock and lifted trucks!
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
vipergtrdj
Sep 11, 2015 05:52 PM
