Problem with Line pressure solenoid in 4L60E?
Originally Posted by digital
I have a Nelson tune, I had the line pressure for the shift points increased in my first couple tunes...
After a retune, which line pressure was returned to stock, my 2000 Silverado still jerks hard through all the gears...
I spoke with someone who advised it could be the Line Pressue solenoid in the tranny. I called the dealer and they had a hard time figuring out what part I needed...
I just wanted to see if anyone has delt with this issue before or has any advice at all...
Thanks everyone,
Matt
Thanks everyone,
Matt
Originally Posted by 02sierraz71_5.3
Its not the silenoid You'll only run into trouble with that silenoid if you decrease line pressure throught the force motor table plus it will set the se light and you'll know it. Id bet money that the tables arent stock and its the tune. Find someone that has HPT and can read it if Nelso hasnt locked the pcm
Thanks for the replies...
What should I do?
What should I do?
I had a local "professional" tuner try and lower my shift pressure by raising the force motor table cough...cough... jeff creech at CAM... cough. It burned up 2 shift silenoids and finally when I got hp tuners I figured it out and set the table back to stock then reduced the voltages slightly. If you want to soften the 1-2 with a shift kit do it in the 1-2 modifier table and the base pressure table. If your gonna adjust the force motor table you can go down in voltage but not up. If either of the shift silenoids is bad it will set an se light and youll loose gears depending on which one it is.
Just to follow up on the topic I started...
I replaced the LPC solenoid with the factory replacement and I'm good to go. She's shifting as she should again..
Thanks to all the replies and especially to Allen from Nelson Performance..
Cheers
Cheers
silverstreak07
Aug 23, 2015 07:09 PM
GMCtrk
Jul 17, 2015 06:39 PM
