Problem with Line pressure solenoid in 4L60E?
Old Nov 5, 2005 | 05:06 PM
02sierraz71_5.3's Avatar
Originally Posted by digital
I have a Nelson tune, I had the line pressure for the shift points increased in my first couple tunes...
After a retune, which line pressure was returned to stock, my 2000 Silverado still jerks hard through all the gears...
I spoke with someone who advised it could be the Line Pressue solenoid in the tranny. I called the dealer and they had a hard time figuring out what part I needed...
I just wanted to see if anyone has delt with this issue before or has any advice at all...
Thanks everyone,
Matt
Its not the silenoid You'll only run into trouble with that silenoid if you decrease line pressure throught the force motor table plus it will set the se light and you'll know it. Id bet money that the tables arent stock and its the tune. Find someone that has HPT and can read it if Nelso hasnt locked the pcm
Old Nov 5, 2005 | 05:17 PM
99Silver6.0's Avatar
It is never a good idea to toy with line pressure in the tables like that.
Old Nov 5, 2005 | 06:33 PM
digital's Avatar
Thanks for the replies...
What should I do?
Old Nov 5, 2005 | 07:15 PM
What should I do?
buy hp tuners
I had a local "professional" tuner try and lower my shift pressure by raising the force motor table cough...cough... jeff creech at CAM... cough. It burned up 2 shift silenoids and finally when I got hp tuners I figured it out and set the table back to stock then reduced the voltages slightly. If you want to soften the 1-2 with a shift kit do it in the 1-2 modifier table and the base pressure table. If your gonna adjust the force motor table you can go down in voltage but not up. If either of the shift silenoids is bad it will set an se light and youll loose gears depending on which one it is.
Old Nov 6, 2005 | 06:04 PM
digital's Avatar
So there's a good chance the solenoid is ok? I need to have Nelson's re-check the tune?
Thanks,
Old Nov 15, 2005 | 11:43 PM
digital's Avatar
Just to follow up on the topic I started...
I replaced the LPC solenoid with the factory replacement and I'm good to go. She's shifting as she should again..
Thanks to all the replies and especially to Allen from Nelson Performance..
Cheers
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
silverstreak07
Aug 23, 2015 07:09 PM
Ferocity02
Aug 7, 2015 08:50 PM
GMCtrk
Jul 17, 2015 06:39 PM
