The problem continues
Old May 15, 2006 | 09:36 PM
12sec.5.3's Avatar
Default The problem continues
I keep breaking my front tranny pump. What the hell keeps causing this? I'm clueless. That's the 3rd one that bites the dust since I put the 6.0 in dec. The first two only lasted about 2 weeks. I spaced the converter on the drive plate which prolonged the last one for about 4 months. What else could I check. Could it be that we messed up the converter when we bolted it up to the wrong driveplate during the swap?
Old May 15, 2006 | 09:58 PM
goshawk23's Avatar
Truck addict
damn todd. i hate to hear this. i don't have any answers for you. i would suppose that if you can send the converter back to be checked out then do so.
Old May 15, 2006 | 10:00 PM
white1's Avatar
Have you had your flexplate checked? A couple of other guys that had that problem had bad flex plates
Old May 15, 2006 | 10:21 PM
12sec.5.3's Avatar
I haven't had the flexplate checked. It shouldn't be damaged since it was from my 5.3. I was using the flexplate from the 6.0 when that happened. Maybe I should get a new one just incase. They can't be that expensive.
Thanks hawk for the sympathy. I need to send it back but just don't want to be down for that long. Let me know if ya'll think of something. I'm gonna check my driveplate tomorrow to see if it spins true.
Old May 16, 2006 | 09:07 AM
OrlandoFL4.8's Avatar
If you dont mind, how does the truck / transmission act when the tranny pump breaks. My tranny just went out all at once yesterday under normal driving conditions. It started to slip a little and by the 5th traffic light, it was slipping so bad it wouldnt move. Some say that I could have lost line pressure.
Old May 16, 2006 | 09:47 AM
dewmanshu's Avatar
Moderately Differentiated
It's warped or out alignment in some way (the flexplate). I went through 2 pumps to find my flexplate was warped. I ended up with 5.3 flexplate and drilled it and extended the slots. I guess it caused problems for me on that occasion.A transmission specialist found it, not me ofcourse. Doesn't take much to knock out those pumps. They are right there in the front, exposed to every millimeter of misalignment.
Old May 16, 2006 | 10:13 AM
Yank's Avatar
LS1Tech Sponsor
You might want to check that the dowl pins are located it the block correctly and in the transmission correctly, if you do not have the crankshaft centerline to the transmission centerline as is could be what you have going on
Note: that the stock flexplate will allow for up to .035 runout at the converter lugs
but and heavy duty aftermarket one has a lower runout range as to the thicker material about .015
Old May 16, 2006 | 10:58 AM
James B.'s Avatar
Is the converter a Precision Industries Vigilante?
Old May 16, 2006 | 11:48 AM
Nick™'s Avatar
Todd, talk to Randy, he's got some extra flexplates he was looking to get rid of.
Old May 17, 2006 | 11:06 PM
bigdaddy1973's Avatar
check converter to crank fit 6.0 out of a 4l80 truck has a larger hole and the converter will have play to break pump
