PPV Brakes on NNBS
Old May 27, 2022 | 07:11 PM
  #51
shakenfake's Avatar
Shlumpt
5 Year Member
Paging @Drspencer come in spencer
Have you made any more progress on these brakes?
I almost want to just put on some of those 20s that Dan posted earlier and eventually find a nice after market wheel.
Old Jul 5, 2022 | 03:24 PM
  #52
Drspencer's Avatar
5 Year Member
My bad. Definitely missed this one. Alright. A BIG update…..they’re installed. They do great things. No rattling. No humming under heavy braking or load BUT…. For those trucks with 13” rotors, there is a part of the inside of the pad, 1/4” at the peak of the radius, that is NOT on the rotor surface. This can cause low speed, low pressure squealing. And it’s Fuggin loud. To rectify this, you just take a grinder to the affected area, the area that is not touching the rotor surface.
Old Jul 5, 2022 | 03:37 PM
  #53
shakenfake's Avatar
Shlumpt
5 Year Member
Pics or it didn't happen
Old Jul 5, 2022 | 05:53 PM
  #54
BigKID's Avatar
I presume you are just chamfering the edge of the pad that is overhanging but I am confused by the 13" rotor mention. I thought these required 16" rotors?
Old Jul 5, 2022 | 08:56 PM
  #55
Drspencer's Avatar
5 Year Member
Yes, I’m just chamfering the edge only where it’s overhung on the inside. The mention of 13” rotors is for vehicles originally equipped with 13” rotors. The 2019+ had 13.5” rotors meaning the caliper mount is 1/4” outward. The 16” rotor package was made for vehicles originally equipped with 13.5” rotors.
Old Aug 28, 2022 | 11:13 PM
  #56
shakenfake's Avatar
Shlumpt
5 Year Member
I just need to know if these or Centerline Stingray IIIs will fit lol
Those Welds I wonder if they would be able to not make it a gloss black, would not look good on my truck imo
Do y'all know if snowflakes fit?
Old Oct 2, 2022 | 05:02 PM
  #57
Drspencer's Avatar
5 Year Member
Alright alright. Finally got around to doing the drivers side and taking photos.
Old Oct 3, 2022 | 12:42 PM
  #58
BigKID's Avatar
Are the pads flaking from the overhang or is that your chamfering?
Old Oct 3, 2022 | 08:20 PM
  #59
Drspencer's Avatar
5 Year Member
From the overhang. I had to pry the caliper off and that part broke off. I then ground off the affected area so it wouldn’t overhang anymore. No more brake squeaking.
Old Nov 15, 2022 | 06:48 PM
  #60
theredgmc's Avatar
Not to chage directions of the thread, just trying to share the info I discovered with my setup. I decided to buy the 6 piston Brembo brakes that a 2023 Escalade ESV-V from Rockauto. But did discover the cheap Dynamic Friction brake pads RockAuto sells won’t fit. They are missing the correct holes for the brake pins. I had to use AcDelco pads. For reference, I bought the newer GM 4 piston caliper set just to take them apart and dissect. The smaller coated pistons shown are from the Brembo 6 piston caliper. The larger uncoated pistons are from the 4 piston caliper. The piston diameter of each, and total surface area is less vs the 4 piston calipers. Witch actually pairs better with the older truck’s smaller master cylinder. Most of the braking performance of the 6 piston kit relies on the larger pad friction surface and 16” rotor anyways, not number of pistons. Since it’s a fixed caliper, I did have to shim the Brembo caliper 3.25mm or slightly over 1/8” to center the caliper on the rotor. In addition, for my wheel to fit over this large caliper, I ended up using a 1/2” wheel spacer.
