Which plus sized rotors?
Old Jun 21, 2008 | 04:05 PM
closet red neck's Avatar
Here, found some info.......
There are a few basic facts that must always be kept in mind when discussing brake systems:
1) The brakes don't stop the vehicle - the tires do. The brakes slow the rotation of the wheels and tires. This means that braking distance measured on a single stop from a highway legal speed or higher is almost totally dependent upon the stopping ability of the tires in use - which, in the case of aftermarket advertising, may or may not be the ones originally fitted to the car by the OE manufacturer.
2) The brakes function by converting the kinetic energy of the car into thermal energy during deceleration - producing heat, lots of heat - which must then be transferred into the surroundings and into the air stream.
The amount of heat produced in context with a brake system needs to be considered with reference to time meaning rate of work done or power. Looking at only one side of a front brake assembly, the rate of work done by stopping a 3500-pound car traveling at 100 Mph in eight seconds is 30,600 calories/sec or 437,100 BTU/hr or is equivalent to 128 kW or 172 Hp. The disc dissipates approximately 80% of this energy. The ratio of heat transfer among the three mechanisms is dependent on the operating temperature of the system. The primary difference being the increasing contribution of radiation as the temperature of the disc rises. The contribution of the conductive mechanism is also dependent on the mass of the disc and the attachment designs, with disc used for racecars being typically lower in mass and fixed by mechanism that are restrictive to conduction. At 1000oF the ratios on a racing 2-piece annular disc design are 10% conductive, 45% convective, 45% radiation. Similarly on a high performance street one-piece design, the ratios are 25% conductive, 25% convective, 50% radiation.
3) Repeated hard stops require both effective heat transfer and adequate thermal storage capacity within the disc. The more disc surface area per unit mass and the greater and more efficient the mass flow of air over and through the disc, the faster the heat will be dissipated and the more efficient the entire system will be. At the same time, the brake discs must have enough thermal storage capacity to prevent distortion and/or cracking from thermal stress until the heat can be dissipated. This is not particularly important in a single stop but it is crucial in the case of repeated stops from high speed - whether racing, touring or towing.
4) Control and balance are at least as important as ultimate stopping power. The objective of the braking system is to utilize the tractive capacity of all of the tires to the maximum practical extent without locking a tire. In order to achieve this, the braking force between the front and rear tires must be nearly optimally proportioned even with ABS equipped vehicles. At the same time, the required pedal pressure, pedal travel and pedal firmness must allow efficient modulation by the driver.
5) Braking performance is about more than just brakes. In order for even the best braking systems to function effectively, tires, suspension and driving techniques must be optimized.
For maximum brake potential, vehicles benefit from proper corner weight balance, a lower CG, a longer wheelbase, more rear weight bias and increased aerodynamic down force at the rear.
To go further it is necessary to understand some of the physics involved, and that requires some definitions.
1) Mechanical pedal ratio: Because no one can push directly on the brake master cylinder(s) hard enough to stop the car, the brake pedal is designed to multiply the driver's effort. The mechanical pedal ratio is the distance from the pedal pivot point to the effective center of the footpad divided by the distance from the pivot point to the master cylinder push rod. Typical ratios range from 4:1 to 9:1. The larger the ratio, the greater the force multiplication (and the longer the pedal travel).
2) Brake line pressure: Brake line pressure is the hydraulic force that actuates the braking system when the pedal is pushed. Measured in English units as pounds per square inch (psi), it is the force applied to the brake pedal in pounds multiplied by the pedal ratio divided by the area of the master cylinder in square inches. For the same amount of force, the smaller the master cylinder, the greater the brake line pressure. Typical brake line pressures during a stop range from less than 800psi under "normal" conditions, to as much as 2000psi in a maximum effort.
3) Clamping force: The clamping force of a caliper is the force exerted on the disc by the caliper pistons. Measured in pounds clamping force, it is the product of brake line pressure, in psi, multiplied by the total piston area of the caliper in square inches. This is true whether the caliper is of fixed or floating design. Increasing the pad area will not increase the clamping force.
4) Braking torque: When we are talking about results in the braking department we are actually talking about braking torque - not line pressure, not clamping force and certainly not fluid displacement or fluid displacement ratio. Braking torque in pounds-feet on a single wheel is the effective disc radius in inches times clamping force times the coefficient of friction of the pad against the disc all divided by 12. The maximum braking torque on a single front wheel normally exceeds the entire torque output of a typical engine.
A few things are now obvious:
1) Line pressure can only be increased by either increasing the mechanical pedal ratio or by decreasing the master cylinder diameter. In either case the pedal travel will be increased.
2) Clamping force can only be increased either by increasing the line pressure or by increasing the diameter of the caliper piston(s). Increasing the size of the pads will not increase clamping force. Any increase in caliper piston area alone will be accompanied by an increase in pedal travel. The effectiveness of a caliper is also affected by the stiffness of the caliper body and its mountings. It is therefore possible to reduce piston size while increasing caliper stiffness and realize a net increase in clamping force applied. This would typically improve pedal feel.
3) Only increasing the effective radius of the disc, the caliper piston area, the line pressure, or the coefficient of friction can increase brake torque. Increasing the pad area will decrease pad wear and improve the fade characteristics of the pads but it will not increase the brake torque.
Old Jun 22, 2008 | 10:37 AM
Red04Silverado's Avatar
I have SSBC brakes on my truck. Not the plus size rotors or calipers just the stock size. Rotors are sloted and the kit also came with high performance pads. Truck stops great and Im running centerline 20's. Thinking about upgrading my calipers with SSBC ones.
Old Jun 22, 2008 | 11:21 AM
fastnblu's Avatar
[QUOTE=closet red neck;3945346]
Originally Posted by fastnblu
To me, 1 1/2# is a small price to pay for better stopping.
I know it is a small price to pay, I was just letting you know what the difference is in weight. I put the 14" 'ers on the front and just the 12" 'ers on the rear. With my research, I found that increasing brake tourqe is only accomplished in a couple of ways. Bigger rotors and bigger calipers(pistons) with a master cylinder to support the calipers(with bigger pistons). If you've noticed on the 3 or 4 piston calipers, the pistons are smaller so the master cylinder will work properly and basically not get over loaded........What I mean is bigger calipers with multipal pistons don't increase brake tourqe.
Let me find the site again and I'll post it up.......
James
I hope u didn't think I was dissing you. That was the 1st time I ever member seein that in writing. I thought the bigger the rotor/ caliper setup, it'd surely stop quicker. I appreciate the info.
This was quite the read. If I understand correctly, the info on line pressure means those braided Russell lines that claim " a firmer pedal", are not really effective?
IDK if I'm more confused or have greater understanding. This is some complicated stuff after all.
I do know this. If I spend over $3k on some big Baers for the front, & whatever for the rears, I'll be really disappointed if they don't stop like I want ( or expect!) them too. I want to go w/ a 14" 2pc. 6 piston setup. Slotted & cross-drilled.
I know that means a 18" wheel & tire( more weight,...& $). If I go bigger than 14", say to a 15", now that adds more wtg, $, & I gotta run 20s. I want go & whoa too. I don't need bling unless it's to fit in BIG BRAKES!!
When u stand on a Z06, it brakes now. That's what I want!
Curious why w/ that big of rim, u didn't go straight to a plus size brake setup?
Old Jun 22, 2008 | 12:12 PM
budhayes3's Avatar
PT's Slowest Truck
The braided lines don't have as much "give" as the stock rubber lines, so not as much line pressure is wasted at the brake hoses, more pressure makes it to the caliper piston.
Old Jun 22, 2008 | 12:15 PM
fastnblu's Avatar
Gotcha!
Old Jun 23, 2008 | 06:30 PM
IMD's Avatar
IMD
Banned
Is Z06 a bolt w/ 16" rims? My guess is no. I'm thinkin for Z06 conv.( depending on year of Z06, one is looking @ a min. of 17" wheels).
even the powerslot + 2, and the eradispeed call for an 18" minimum. you arent going to get bigger rotors under a 16" wheel period.
Old Jun 23, 2008 | 06:48 PM
Rafedial's Avatar
Same here....
SSBC's standard size rotor and pad kit bring my ecsb 4X4 to a stop quick. Will fit a 16 inch wheel. 20,000 miles and no issues, or excessive wear. I also haul a light trailer every other weekend. $380.00 most places.
Old Jun 23, 2008 | 07:54 PM
skyhighsami's Avatar
no title here
If you would please send me the link where you can get all 4 rotors and pads for 380. I was seriously considering ordering them straight from SSBC tomorrow for my wife's Yukon. Thanks
Old Jun 25, 2008 | 09:28 PM
fastnblu's Avatar
That was my thinkin exactly. I know on Camaro hd brakes, they were trimmed( if u will) to make em fit, something that wasn't needed from the Vettes' they were borrowed from. I didn't think u turned the diameter down to make Z06 rotors fit a Silvy, but u never know.
I usu. figure ~4" difference for rotor compared to wheel size. Of course, always measure.
ex. 16" rim = ~12" rotor or 18" rim = 14" rotor, & so on.
Old Jun 25, 2008 | 10:46 PM
Fastnblu
I have Centerline ultralight Archers, each wheel and tire weigh around 50 pounds each (roughly). Not to much different from my stocks far as weight. I have no brake fad and stops on a dime. When I bought the brakes I had 18s on my truck at that time.
