Plumbing a TruCool
Old Dec 11, 2008 | 10:23 PM
  #21
Originally Posted by 006rcsb
lol yeah its the 40k gvw tru cool model 110 bucks on ebay, couldnt pass it up
Do you know what kind of fittings are the stock lines for the towing package cooler?
I have the B&M cooler that has female 1/2 ports and was wanting to adapt them to the auxilary cooler or possibly run it in series with it. I was hoping to be able to get some fittings for a bolt on install instead of cutting the lines.
Would you remember of by hand what they are?
Thanks and sorry for the hijack but hope it helps the OP too
Old Apr 18, 2010 | 01:25 PM
  #22
budhayes3's Avatar
PT's Slowest Truck
Bringing this back up to the top for info and links (via PM please if not forum sponsors )
Curious is anyone has found the fittings that go into the cooler itself yet, or if just a threaded fitting of the proper pitch and size thread will work...
Old Apr 18, 2010 | 06:24 PM
  #23
fastnblu's Avatar
Originally Posted by charcold-bowtie
Most people run the -6 size, I did. They make fitting that go to the hard lines, I cant remember if its 5/16 or 3/8 though... I went through my factory radiator and just cut the flare off, and used those to get onto those lines and on to the -6
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
Thanks man, -6 AN was the size I was planning on, I'm hoping someone knows what size fittings are on the cooler, as well as the hard line size, and what size goes into the radiator. I believe that I've read that the radiator fitting is 16mmx1.5, but I'm not sure.
I'm definitely going for the thermal bypass, our winters get pretty cold. The needle on the trans temp gauge in my cluster doesn't even move during my drive to work in the morning. I'll be doing a Yank TT3000 when I do the trans...
How's that TT3000 workin out? :
Originally Posted by krambo
It is a 3/8 INVERTED FLARE going into the cooler (if you have the same cooler as I do...40K GVW Trucool). I had a hell of a time finding a Male 3/8 inverted flare to a male (or female) -6AN . I found one however the inverted flare end was too short. Let me know if you find one. I was able to find a male 3/8 inverted flare to a Female -8AN but I didn't want to mess with it. I ended up using the barbed fittings that came with the cooler and -6 Push Lock hose and fittings until I find my fitting.
Here is the link to the fitting however the damn inverted side was too short!
http://www.tallonhydraulics.com/stor...products_id=16
I got black -6AN Pushlock hose from Jegs. I used all 25ft of it as well to go from the tranny to the cooler. Yea, with 25ft there is plenty of leftover however I haven't tucked it all up nice and neat yet so I kept all of the slack. I also turned my fittings on the tranny to face backwards. It was just a bit too tight to come out the front IMHO. Here are how the tranny fittings look:
Krambo sure has a sweet setup on those lines too.
...I ran mine forward with the 90's, would be a lot better with 45* fittings. The dipstick can be quite a PITA to get in.
I like the looks of the fittings and hoses on your trans...just have to find the fittings to the cooler...if there is such a fitting
Hey Krambo, are the threads going into the cooler 3/8 NPT? If so, would it be possible to use a 3/8 NPT to -6 AN fitting with some sealer on the threads going into the cooler?
And has anyone been able to verify what size the hard lines back to the trans are (3/8?), as well as the fitting into the radiator?
... 3/8 NPT will not thread in...I tried (wanna buy some nice 3/8 NPT to -6AN fittings ). You can force them in there and screw up the thread pattern if ya want to...I thought about it. What I was going to do when I get some free time was to cut about 1/4 inch off the cooler fitting so that the fitting that I linked above will work. UNLESS someone else has a link to a fitting that will work
Not sure on the stock tranny line size.
Originally Posted by Websy21
Do you know what kind of fittings are the stock lines for the towing package cooler? ...
Ya, there's a reason I'm called Multi-Quote Maniac!! Even this might be a record for me tho. All these quotes are here for very good reasons; some good info. It would be great if some sizes are verified. At that time, maybe someone, could do a sticky that details the sizes -AN & NPT, fitting style 45* or 90*, how many, what length, what cooler if not using a TruCool 40K.
I believe it would help a great deal of people. No matter the engine, or if it's N/A or F/I, how many cubes, etc. None of that matters, but there's a 60E in lots of rides; surely most are using a cooler on their trannies I hope.
Old Apr 18, 2010 | 07:35 PM
  #24
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Guess Im going to have to add a link in the sticky section for plumbing a trans cooler with AN fittings. Ill make one here in the next week or so. For reference for now look at post 15 in this thread
https://www.performancetrucks.net/fo...t=trans+cooler
Old Apr 18, 2010 | 07:44 PM
  #25
budhayes3's Avatar
PT's Slowest Truck
LOL, ha ha ...I know you know, but for others who may be reading this...I went a different direction....it's called "we dare you to break it", by the good folks at Circle-D
https://www.performancetrucks.net/for...t=trans+cooler
Today 07:24 PM
Thanks Cody
Old Apr 18, 2010 | 08:32 PM
  #26
fastnblu's Avatar
Thanks!
Old Apr 19, 2010 | 12:32 AM
  #27
budhayes3's Avatar
PT's Slowest Truck
How about the factory auxiliary cooler setup? The more I think about it, I like the idea of having hard lines run throughout the system. Only thing is, I already cut the return line going into the radiator, and may need to replace it if it isn't part of the kit that GM offers for the towing package auxiliary cooler kit. Anybody have any pics of their factory cooler set up? Including shots of how the aux cooler lines are run, and how the return, from the upper port in the radiator is run? That would be great!
*EDIT* After looking at it, it appears that the kit comes with the line from the radiator to the cooler, then from the cooler back to the trans, then I could sell the cooler itself as brand new, and it's less than $100
PN:12497071
Old Apr 19, 2010 | 09:12 AM
  #28
1slow01Z71's Avatar
search my name in here for pics of the factiry cooler setup. I've gone through all of this a few times lol.
Old Apr 19, 2010 | 11:29 AM
  #29
budhayes3's Avatar
PT's Slowest Truck
Will do, thanks again Cody How about that Allen wrench for the t-case fork, do you have a description on that one? Is it a tamper-proof or something? (hex has a little hole in the middle?)
Old Apr 19, 2010 | 10:50 PM
  #30
1slow01Z71's Avatar
Nah its just big 12mm
