Please check out my gear pattern for my 4.56s
Old Jan 29, 2015 | 11:25 AM
chevyridinhigh22's Avatar
Originally Posted by Jeebalow
Are you measuring the backlash with a dial indicator like Axis does in the write up? Those 0.007" WILL be the difference between a quiet long lasting gear set and a noisy set that only lasts a few hundred miles. Get that into spec before taking any patterns, otherwise it's a waste of your time.
yes similar except digital. Okay, ill get that in spec then recheck. Thanks man
Old Jan 29, 2015 | 01:09 PM
Alright,Got it down to .003-.004"
Is this pattern acceptable you think? Im sure ill have to open up the backlash a little, its just so close I don't wanna mess with it.. The backlash initially with the first pic was .028'
Old Jan 29, 2015 | 01:13 PM
Jeebalow's Avatar
Still looks too far to me man. What shim thickness is in there? What gears are you using? This in a 10 bolt right?
Edit- Maybe PM axis so can take a look. His word is worth much more than mine on this.
Also you may want to add a tad more oil to the paint. Should be like a chocolate sauce consistency.
Old Jan 29, 2015 | 01:27 PM
Ive been wondering why my patterns wasn't coming out as well as others. I thought I have too much oil. ill shoot him over a pm. My pinion has the stock shim behind it. It is a 10 bolt, I have g2 gears 4.56 Thanks for your help bud
Old Jan 29, 2015 | 01:31 PM
Jeebalow's Avatar
No problem man, I would add 0.003" at a time. Have you measure the stock shim? I asked about gears and diff because maybe someone has already setup those same gears in that same diff and you could search to see what they used. Axis has the how to thread on multiple forums and I was going to check for you if anyone did it in another one of the forums so you'd have a good starting point. You could also give that a shot.
Old Jan 29, 2015 | 01:37 PM
Stock pinion shim should be .37". Here's the Drive side if that helps, I'm pm'in axis now
Old Jan 31, 2015 | 12:09 PM
axisT6's Avatar
Call me - 2816365243
Stainless Works
Apr 10, 2016 04:34 PM
ALL ULL C
Aug 16, 2015 08:56 PM
97aztecgt
Aug 13, 2015 02:11 PM
Stainless Works
Aug 4, 2015 12:56 PM
iregret
Jul 27, 2015 10:32 PM
