pinion shim, wich one?
Old Nov 25, 2009 | 05:45 PM
JoeGibbSilverado's Avatar
Default pinion shim, wich one?
In the rear of my truck i have 2" shackles, the 2" hangers, and no overload, and i have some -4 degree shims, but since the hanger install, ive had a slight vibration on take off and around 55-60, what shims are you guys running with this amount of drop?
Old Nov 25, 2009 | 05:49 PM
dirt track racer 81's Avatar
I have about the same drop. I cut the leaf spring pads off and re-welded new ones on with the correct pinion angle
Old Nov 25, 2009 | 05:56 PM
got ya, not up for that project right now, but great idea, im going to just shim this biieeetch
Old Nov 25, 2009 | 06:43 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You'll need to measure the driveshaft to pinion angle that you already have, then see which shim you need(replace the existing shim) to end up at between 3-5 degrees.
Old Feb 18, 2010 | 11:56 PM
BadAssChevy327's Avatar
i was changing my rear shocks tonight and notice my pinon is facing upward pretty bad. but i have no vibrations at any mph or take off. it doesnt hook even on a 15 mph roll so i cant even judge from a dig lol.
its werid how its so smooth for having such a bad angle.
Tigger Welder
Oct 1, 2015 08:41 AM
twake_410
Sep 25, 2015 10:09 PM
97_ek
Sep 23, 2015 09:16 PM
03chevytruck
Sep 10, 2015 10:18 PM
