Peg Legging
Old Aug 13, 2006 | 12:39 PM
MikeGyver's Avatar
Default Peg Legging
It's happened twice, now. I'll pull out into traffic with enough time to not make the guy that I'm pulling out in front of slow down if I floor it. Except that when I floor it, coming out of the turn, it lights up the inside tire, and I become a smoke-screen producing road block.
Since it happened twice, does that mean that I smoked the Posi's clutches the first time, and need new ones? Or does it mean I need stronger springs or something in the Posi?
Or does it mean that I have to change to a locker?
Thanks, Mike.
Old Aug 13, 2006 | 01:38 PM
Dock Rocker's Avatar
Thanks, Mike.
That just means you have a g80 probibly...Even my eaton one wheel peels if I am making a sharp turn. I think you have to have a true locker to get a true two wheel burn while turning but it is going to cause many more problems than you are going to fix.
Old Aug 13, 2006 | 04:13 PM
MikeGyver's Avatar
Originally Posted by Dock Rocker
... but it is going to cause many more problems than you are going to fix.
Such as? Educate me, please.
Old Aug 13, 2006 | 04:36 PM
RoninsDenali's Avatar
A true locker (such as the detroit locker) physically locks during torque transients. This makes for some harsh/difficult turning as the inside wheel is being forced to turn at the same speed as they outside wheel.
A Eaton LSD might be a better option, better grip for launching and excellent drivibility. (or any other reputible LSD)
Old Aug 13, 2006 | 05:27 PM
TIM Z's Avatar
11 sec. Truck Mod
These g80's are weak and dont seem to like power greater than stock. I would definitley if budget allows get a detroit true trac, it has no clutches and it grips and performs tenfold over the g80 i had. My G80 broke and took out the pinion gear costing me about 900$ . Get a locker before it breaks and save yourself some time and money, or just baby the rear cuz it will break.
Old Aug 13, 2006 | 06:29 PM
MikeGyver's Avatar
I was looking at the TrueTrac, but I read that the wheel with traction is given 5 times the torque of the spinner. So does it spin both wheels (fishtail) around corners?
Old Aug 13, 2006 | 06:39 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yes.
I have the same problem when i pull out and floor it, i just sit there and spin both tires now.
I dont know the actual mechanics of it, other than its a clutchless LSD but both wheels have some torque to the ground when hammered.
Old Aug 13, 2006 | 06:41 PM
TIM Z's Avatar
11 sec. Truck Mod
i dont know if i can give you a fair answer, before and after if i d punch it around the corner it was scarry! i think youll be happy with it though. great well built unit.
Old Aug 13, 2006 | 08:17 PM
03sierraslt's Avatar
TimZ's will spin both around a corner, he took me for a ride in it and you could feel the rear end drifting out. This was at around 30 or so mph, I dont remember.
Old Aug 13, 2006 | 09:37 PM
MikeGyver's Avatar
That's what I wanted to hear.
max_ta
Nov 10, 2015 07:50 PM
slowmo934
Sep 9, 2015 12:24 PM
Isak81
Aug 29, 2015 01:44 PM
dantheman1540
Jul 29, 2015 04:45 PM
gafool
Jul 28, 2015 05:20 PM
