Parking and ABS lights on dash?
Old Oct 2, 2005 | 01:36 AM
Default Parking and ABS lights on dash?
What would cause the parking and ABS light on the dash to come on randomly? It turns off with the truck, and will come back on in no predictable fashion.
I can be driving and not touching the brake, and it comes on.
I can be touching the brake and it comes on.
It's more a nuisance then anything
Help.
Old Oct 2, 2005 | 02:05 AM
black4x4's Avatar
did you change gears or tire size?
Old Oct 2, 2005 | 03:28 AM
I changed wheels and tires from OE 16" wheels to 17" Z71 wheels and tires about 6-8 months ago. This started about 3 weeks ago.
Old Oct 2, 2005 | 03:45 AM
Mr. Sandog's Avatar
Did the overall outside diameter of the tires change?
Here's a calculator to help if you need it.
Old Oct 2, 2005 | 03:51 AM
OCBC's Avatar
on my toyota the rear drums would where down to a point that the position of the pads would be far enough down to cause the e brake light to come on. It was my accidental way of telling I needed new brakes in the rear.
Old Oct 2, 2005 | 04:01 PM
budhayes3's Avatar
PT's Slowest Truck
Best way to tell what's going on is to get the ABS system scanned for a code. Since the light comes on intermittently, there might not be a hard code stored in the computer and you may need to catch it when the light is on.
Old Oct 2, 2005 | 10:56 PM
Jeff Alexander's Avatar
first check the basic, check your resevior for the master cylinder if there isnt enough fluid it will turn on the light. its probably not that but its worth a shot
Old Oct 2, 2005 | 11:02 PM
also you said it turns off when you start the truck but when you drive it turns on, check your wheel speed sensors, some times they get full of grease, metal shavings, and other things. just clean them off if thats the problem.
Old Oct 3, 2005 | 12:38 AM
graystepside's Avatar
I do not beleive tire size is the problem. i have changed sizes and no light ever came on. my brother never changed sizes but his light comes on.
carid
Oct 28, 2015 08:24 AM
kalikid06
20
Oct 13, 2015 07:37 AM
Tigger Welder
Oct 1, 2015 08:41 AM
03chevytruck
Sep 10, 2015 10:18 PM
the owl
Sep 4, 2015 04:09 PM
