P0300 Random Misfire Code make TC not lock up??
Old Jul 19, 2011 | 09:00 PM
BIG_D_74's Avatar
Default P0300 Random Misfire Code make TC not lock up??
I've had the P0300 and occasionally P0307 code pop up and I haven't gotten around to fixing the problem, but I noticed today that my TC wouldn't lock up. If the misfire is fixed will this remedy my TC problem or am I looking at two separate problems? 2004 RCSB 2wd Mods are in sig.
Old Jul 19, 2011 | 09:26 PM
Vince B's Avatar
More than likely that is your issue! Get it fixed before you do further damage. Engine misfires are you issue if I had to guess.
Old Jul 19, 2011 | 10:10 PM
Wilde Racing's Avatar
How do I change this text
Verify the engine is not misfiring, if all checks out, you need to raise the threshold of the misfire tables. The smaller converter has a much lower rotating mass and as such the PCM "see" the now more apparent engine pulses and mistakes them as misfire. I believe the tuning guide mentions something about this issue, if it does not please let me know so I can add it....
Old Jul 19, 2011 | 11:23 PM
BIG_D_74's Avatar
I've been running the same tune for 7 months now and no issues until now. Checked everything out and turned out the spark plug was bad at least I think. It had some carbon build up on the porcelain jacket. I checked a few others they all looked good minus the carbon build up on the jacket. I'm guessing the spark plug is shorting out. I'll put a new plug in and post up.
Old Jul 22, 2011 | 12:37 AM
BIG_D_74's Avatar
After I put the plug in I still got a P0307 code. So then I swapped wires with the #5 cylinder and then I swapped coils. I still got the P0307 code. What should I do next? Compression test?
Old Jul 22, 2011 | 02:47 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
A compression test is a good idea, and easy to do. I'd also say to move the injector to another cylinder.
Here's a wierd one....... I chased this one around for a while before I figured it out. A partially clogged cat can throw a misfire code, and no cat codes, and no performance issues that are noticable. In my case, I kept getting a P0303. Moved everything to different cylinders, and checked compression. No trouble found anywhere, and still had the same P0303. Got a tip from an old friend, and checked backpressure. I had 3 psi backpressure on the left cat at idle, and 5 psi at 3000 rpm. Replaced the cat/y-pipe and fixed the problem.
Old Jul 24, 2011 | 10:12 PM
BIG_D_74's Avatar
That's what I did. I checked all 4 cylinders on that side. They were all about 140 psi so that made me feel better. Then I did an impedance test on the injectors and they all turned out exactly the same. I pulled the #7 injector and it was completely full of dirt. I cleaned it up and checked the others also. I put it back together and tore one of the o-rings so I couldn't drive and see if I fixed it. I'm guessing that's what was wrong.
Corvette454l88
Sep 1, 2016 01:24 AM
97aztecgt
Aug 13, 2015 02:11 PM
noproblems209
Aug 10, 2015 06:57 PM
Three6GMC
Aug 3, 2015 07:53 PM
lo&sloSierra
Jul 24, 2015 07:03 PM
