Output angle to far down!! HELP
2017 sierra crew cab 4x4 lowered 5/7. My t case angle is pointed -6 degrees down and i cannot go any higher. My driveshaft is at 0 degrees and pinion is set at +4 degrees. I have already shimmed it as much as possible, any higher and it hits the tunnel. Still getting unwanted vibrations I am sure its due to the working angles. What are my options here? I thought about lowering the engine with aftermarket mounts but I don't want to cause anymore issues.
Cut out the axle spring perches and reweld at the correct angle?
I've never hear of anyone lowering an engine. How would you even try to do that? 🤔🤷
Atomic fab make engine mounts that will sit the engine a 1/2" lower. My issue is not the pinion angle, i can shim that to whatever angle i want. It is the angle of the t case pointing down 6 degrees. and the driveshaft being at 0 degrees makes the working angle way off.
strutaeng (02-20-2024)
walledition
02-03-2016 09:54 AM
agreif
09-10-2006 11:40 AM
