Drive shaft angles probs w/ lowering kit
Old May 11, 2008 | 02:35 AM
XLR8N's Avatar
Default Drive shaft angles probs w/ lowering kit
I'm looking at doing a 3/4 drop on my 03 rcsb. I crawled underneath the truck to look at the driveline set up and i noticed that the pinion is all most as high as transfer case output, now if i lower it 3-4 inches the pinion will be higher than the output. Has anyone had these problems before, any solutions?
Old May 11, 2008 | 09:21 AM
TXsilverado's Avatar
djm makes a driveshaft carrier that tucks up closer to the bed. thats what im using anyways???
Old May 11, 2008 | 09:28 AM
454navyss's Avatar
pinion shims
Old May 11, 2008 | 09:29 AM
Originally Posted by 454navyss
pinion shims
he's saying that the pinion is level with the driveshaft carrier and he's afraid that after lowering the truck his axle/pinnion will sit above the driveshaft carrier.
Old May 11, 2008 | 09:39 AM
454navyss's Avatar
oh ok, i see what he is talking about now
Old May 11, 2008 | 10:41 AM
XLR8N's Avatar
I have a rcsb and there is no carrier on it just one solid shaft. I'm going to get underneath it again to measure both the pinion and transfercase tail shaft angles.
Old May 11, 2008 | 10:44 AM
lady3bglover's Avatar
I have the Belltech complete 2/4 drop kit including the carrier. We did have to remove the OEM ds carrier to install.
Old May 11, 2008 | 10:47 AM
XLR8N's Avatar
I'm planning on running the McGaughy's shackles, hangers and keys if that makes any difference.
Old May 12, 2008 | 05:45 AM
Xlr..
Why don't you call the manufacturer for suggestions? They do have a carrier bearing relocator.
http://www.mcgaughys.com/truck_new.html, top part of the page.
Lisa
Old May 12, 2008 | 07:44 AM
XLR8N's Avatar
I would run that but i don't have a carrier bearing to start with.
