Opinions wanted
Old Sep 17, 2011 | 10:47 AM
fastrt's Avatar
11 Second Truck Club
Default Opinions wanted
I just swapped my spring/spindle 4" drop for uca/lca djm front drop. I was told it was for a 4" drop, but it looks to be a 3" drop. I have a 6" flip kit out back. I like the way a 3" drop rides over a 4" around my area, but the 4/6 "looks" better. Question is, would you....
1. put a 1" drop coil in?
2. cut the stock coil an inch?
3. raise the back up an inch with a lift shackle?
I like the LCA ride over the old spindle/spring setup. I had a mcgaughys 1" spring on my old 3" drop, but the 2" hotchkis spring on the 4" drop was too hard and I hated the ride. Thanks
Old Sep 17, 2011 | 12:01 PM
robert85's Avatar
MASS seller approved
If you got the money I would buy the springs! If not then just cut 1 inch off the springs in there now! I installed 2" springs and 2" spindles on a 93 rcsb that I have and a 6" flip kit on the rear and when I sat it down the front still seemed to sit high....at first i thought maybe I installed the springs upside down...lol...but I didnt and so I took them out and cut a inch and a half off the beltech springs to get the height that I wanted! I used a cut off wheel, not a torch...lol! Hope that helped!
Old Sep 17, 2011 | 01:52 PM
dlt76028's Avatar
when I took my drop coils out and cut my stock coils, it rode 100x better. I cut one full coil to drop 3", so you might start with half or less.
Old Sep 17, 2011 | 03:48 PM
fastrt's Avatar
cut it off the bottom of the coil right? the top is flat so it sits in the top flush. It rides so much better than any thing i have had so far. stock coil is where it is at.
Old Sep 17, 2011 | 04:24 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'd raise the rear up.... If you like the front, leave it alone IMO
Old Sep 17, 2011 | 04:25 PM
dlt76028's Avatar
i believe it was the bottom, and then just rotate it so it sits in the groove.
Old Sep 17, 2011 | 06:22 PM
robert85's Avatar
I cut my from the bottom and did the same as far as rotating it into the groove!
Old Sep 17, 2011 | 10:30 PM
fastrt's Avatar
I do like it, but I dont think 1" will make a diff. It did not on the old 3/4 from 2/4. I think its all in the spring. I used a mcgaughys 1" that rode nice, and made the truck handle better in the corners. I think i need to see how my 15x10" centerlines are gonna fit in the current stance before I make a final decision. I dont want them to hit the bed cause they will stick out past the bed on a 28/10.5/15 M/T slick.
Old Sep 18, 2011 | 08:16 AM
built408's Avatar
I would cut the front spring before you consider buying a drop spring. Every drop spring I've had always rode like ****.
Old Sep 18, 2011 | 12:02 PM
fastrt's Avatar
I agree, I went back and searched tons of old threads where Ben, and Lance, and Skeet and others had done their coils, even David. i think it would be better to just cut 1/4 to 1/2 coil off, with about 1" more on the passenger side to fix any lean.
