opened the diff...found this (with pix)
Old Dec 9, 2010 | 03:43 AM
  #71
m3srt's Avatar
Banned
i dont see any problem ?
Old Dec 14, 2010 | 12:32 AM
  #72
EVILGMC's Avatar
Ordering forged axles this week.
Old Dec 14, 2010 | 10:47 AM
  #73
1FastBrick's Avatar
Custm2500's Rude Friend
Uh oh.... Won't you need a new set of gears first???
Old Dec 14, 2010 | 01:05 PM
  #74
EVILGMC's Avatar
Crunchy
Old Dec 14, 2010 | 06:05 PM
  #75
Swerve7rpm2000's Avatar
I thought I was good at working some *** over but seems u did a number on that rearend! I'll be in the samn boat a u soon I imagine, I have the 10 bolt with eaton and 4.11's, might have to change gears now due to goin turbo
Old Dec 15, 2010 | 08:30 AM
  #76
EVILGMC's Avatar
I try...
Old Dec 15, 2010 | 08:26 PM
  #77
Mr. Sandog's Avatar
Vacuum it out and you'll be fine.
Only OEM gears for me.
Old Dec 27, 2010 | 12:36 PM
  #78
GoatChs's Avatar
Default 14-bolt modification
Located a 5k mile tbss takeout for a good price. Now just need to finish the axle housing modifications and decide on gear ratio. I have both 3.73 and 4.10 at my dispoal. And I need to order the TA cover. I am leaning towards 3.73 again since 4.10 was a handful on the street at 8psi...15 be downright silly. Not to mention zero traction in 1st. Input welcome.
Its not. Your a hack!!!
04 VHO had a 10bolt
05 VHO Had 14 bolt
06 The name changed to V-max
TBSS are shorter then the truck rear.
Some H2's had the 14 bolt too!!!
Curious about how much narrower the TBSS axle is than NBS truck axle? Enough to require any wheel offset changes for fitment?
Old Dec 27, 2010 | 01:20 PM
  #79
dhpro's Avatar
So...I think you got real lucky...I'm on 10 bolt #4! Here's some pix of my G80 and the yoke it broke when it grenaded - took the tranny with it!!! Next few were bad installs but I had a whine that gave me warning at least...one had a cracked pinion the whole length, the other wasnt broke in prop - looks like that might be what happened to you frankly. The current was set up nice - its an ART, but I'll be going to the 14 bolt next spring (07 Avv & Hummer version). They're 3/4" wider, but who gonna notice that!
Old Dec 28, 2010 | 01:33 AM
  #80
1FastBrick's Avatar
Wow You do Nice work!!!
His gears sheared because of all the Power from the TVS2300 and he finally put slicks on it. There is a reason why GM upgraded to the 14 bolt when they finally built the performance 2WD plate forum in 05.
