One More Way to do a 80E wiring swap
Old Dec 23, 2014 | 05:47 PM
  #21
tgui's Avatar
For dumb people like me, this method requires a segment swap via HPTuners or the like?
Old Dec 23, 2014 | 05:52 PM
  #22
03sierraslt's Avatar
Yes it does.
Old Dec 24, 2014 | 12:09 AM
  #23
tgui's Avatar
Yes it does.
Thanks!
Old Apr 17, 2015 | 03:33 AM
  #24
jetfixrguy's Avatar
good info! Thanks!
Old Jan 23, 2016 | 03:55 PM
  #25
Sarg's Avatar
So realistically this could be done with any of the three options for the primary, just might use a different wire at the ecu.
Old Jan 24, 2016 | 12:46 PM
  #26
Sarg's Avatar
Exploring Alternate 1 and 2
Alternate 2:
Remove brown wire from pin 2 in Red/Green connector
Remove white wire from pin 79 in blue connector
Insert white whire into pin 2 of red/green connector
Brown wire moved to pin 22
Remover tan/blk wire (T) remove from pin 42 and move to pin 23
Brown wire is used as pin A in speed plug
Tan/blk is pin b in speed plug
__________________________________________________ ___________
Alternate 1
Or cut white and brown and solder brown wire to remaining white at trans plug
Wire white wire to pin A in speed plug
Tan/blk to pin B on speed plug
Remove pin 79 white wire and move to pin 22
Remove pin 42 and move to pin 23
Old Jun 23, 2017 | 10:31 AM
  #27
unt0uchable's Avatar
Can I resurrect this one from the dead?? I'm in the midst of swapping a 80e/246 from a 2003 2500HD into my 2002 Tahoe Z71. The trans I have only has one VSS on the side, t-case has 3 on it. I can't find a definitive "yes" for this question on all the sites and forums - do I need install the second sensor onto the trans in order for this all to work right? Everything I'm using was pulled form 4wd vehicles. Thanks to anyone that can help!!
Old Jun 23, 2017 | 11:58 AM
  #28
TrendSetter's Avatar
no, since its 4wd the rear speed sensor is on the output shaft of the transfer case
Old Jun 23, 2017 | 12:58 PM
  #29
This.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
1slwgto
Aug 16, 2015 06:40 PM
05GMC4.8
Aug 7, 2015 09:55 PM
iregret
Jul 27, 2015 10:32 PM
JordanH
Jul 14, 2015 03:46 PM
