older 4l80e into 2000 truck? will it work
Old Nov 8, 2007 | 07:34 PM
SimpleManLance's Avatar
Default older 4l80e into 2000 truck? will it work
i was wondering if a 4wd 4l80e trans out of a 97 truck will work on my 2000 Sierra? thanks im looking to do the swap and came across a good deal. not sure if it will work though.
Old Nov 8, 2007 | 08:19 PM
Wilde Racing's Avatar
How do I change this text
Yes I'm pretty sure it will, as long as it has the mounting bosses for the neutral safety switch
Old Nov 8, 2007 | 09:05 PM
James B.'s Avatar
Yes. 1997 and up is the revised case with the rear fluid inlet.
Old Nov 8, 2007 | 09:49 PM
thanks for the info. is there anything i can look for to double check it.
Old Nov 8, 2007 | 10:12 PM
FLT's Avatar
FLT
FormerVendor
It will work Lance however the bolt hole at the 12oclock position is not there on that 97 case. You might want to locate a 99 and later unit. Vince
jdb11386
Dec 3, 2015 09:34 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
350SS
Jul 11, 2015 12:34 PM
