oil seal leakage
Old Jan 14, 2011 | 06:52 PM
RotaryResurrection's Avatar
Default oil seal leakage
A few months ago I noticed I was getting light oil leakage from a couple of seals on the front axle, tcase, and diff of my 02 denali, and since it had 120k I decided it was time to go ahead and replace them (and the fluids inside).
I replaced every oil seal in the drivetrain with a new GM OEM seal. All 3 on the front axle, both on the outside of the tcase, and the rear pinion/diff seal.
Since then, maybe 2 months, the pinion seal is seeping/leaking a slight amount. One of the output seals on the front axle is leaking a bit more, enough to wet the side of the diff.
We've had snow this week. Last couple of days I notice the snow under my truck is blue...dead giveaway that the tcase is leaking the autotrak fluid. I get under it and look, and the tcase rear seal where the driveshaft yoke goes in is really wet.
WTF? I didn't bend any of the seals on install, I used pipes, large sockets, chunks of wood, etc. to install them without bending or distorting them. The driveshaft front yoke is also brand new so it couldn't be responsible for damaging the rear tcase seal.
Is there some special procedure or magic trick for replacing these seals that I'm not aware of?
Old Jan 14, 2011 | 07:46 PM
Beatdown Z's Avatar
Laid Back
Did you install them dry?
Old Jan 14, 2011 | 09:13 PM
The GM seals come with grease on the inner lip already, and I used vaseline on the outside edge and the metal bore they were going into.
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
600 horses
Sep 10, 2015 11:01 AM
mayko
Sep 7, 2015 12:24 PM
